[ Total Views: 1159 | Total Replies: 8 | Thread Id: 49218 ]
Author: Subject:  Liberty 92 Adaptor gearbox question
Membervwpete
A.k.a.: Pete
Mood: Jolly
posted on February 23rd, 2006 at 01:13 PM
OOk I have bit the Bullet and am finally gonna try out one of these Subaru washing machine things.
Just put deposit down on a ej22 liberty 92 engine, should have it in a week or so.
My plan is to put this in my Chenoweth rail (not road licensed), I have done a fair bit of research and have read through gazillions of posts on this forum and others.
I rang up COR regarding Adaptor kits, to be told that sticking this motor onto a 1600 combie box has issues, I apparently need a 2 litre box or at least a 2 litre bell housing plus the long guide tube.
Has anyone come across this and do ya have any tips to shoe horn this thing onto a 1600 box?
I am only interested in the mating of the motor to me gearbox for now.
I have already filled my head with the other works
Like wiring, sump, fuel, bottom mount, cooling and exhaust etc. but I am sure u will see posts from me on that when I get to them.
Plus if anyone is interested, I can start a progress thread showing how I get on and provide the PIics, Gotcha’s and pricing along the way.
So far I paid $900 for an ej22 92 with full loom exhaust headers sensors and radiator
Memberseagull
Threads: 752
posted on February 23rd, 2006 at 08:07 PM
I have a template of the adapter plate of a 1600cc box you can use .
Membervwpete
A.k.a.: Pete
Mood: Jolly
posted on February 26th, 2006 at 07:49 PM
perfect, when can i come and pick it up?, how about the fly wheel any info there?
oh yeah and thanx
[ Edited on 26/2/2006 by vwpete ]
Member71EJVan
Threads: 23
posted on February 27th, 2006 at 07:08 AM
EJ22 will fit into a 1600 kombi box but you will need a 200mm adaptor kit and not the 228mm one. If CORC don't have them Volksconversions do.
A VW for everyone!!
1972 1302 German Look
1971 Bay Panel with Subaru EJ20T
1970 Type 3 squareback in progress
1971 Type 3 notchback in progress
http://i6.photobucket.com/albums/y208/GL1972/GL1972F3DKbanner.jpg
Membervwpete
A.k.a.: Pete
Mood: Jolly
posted on February 27th, 2006 at 01:12 PM
Thanx for that info, I rang john at Volksconversions, Man that guy he knows his stuff.
Has anyone had any issues with using a standard beetle 200mm clutch with an ej22, will it slip? Do I need to use a heavier clutch plate??
Memberratbug
A.k.a.: Andrew Todd
aka toddy101
Threads: 30
posted on February 27th, 2006 at 02:34 PM
I run a standard 200mm clutch disc with a heavy duty pressure plate (kennedy stage2). Doesn't slip at all on an ej20. I originally had a standard vw pressure plate and a 5puck ceramic button clutch, this wouldnt slip at all and was a pain to drive on the streeet. Just get a heavy duty pressure plate
Manxter with FA20turbo
Click here for wiring looms
Memberseagull
Threads: 752
posted on March 1st, 2006 at 01:50 AM
Rat bug , can you u2u your postal address .I would like to send you this Vw book & a gift for the ecu you sent me , cheers Neil
Member71EJVan
Threads: 23
posted on March 1st, 2006 at 08:39 AM
I'm going to run a 2100lb 200mm pressure plate and HD clutch plate in a bay kombi with a EJ20T.
A VW for everyone!!
Memberseagull
Threads: 752
posted on March 10th, 2006 at 09:15 PM
I have some adapter plates getting made now , should you need one pete , drop me a u2u , seagull
[ Queries: 40 ] [ PHP: 11.3% - SQL: 88.7% ]
