| [ Total Views: 1128 | Total Replies: 4 | Thread Id: 50110 ] |
Stanley
Threads: 270
| posted on March 22nd, 2006 at 08:24 PM |
ok whats the magic trick... (irs arm removal)
just remember it's probably been in there for thirty years....give it a good soaking with WD40 etc and let it sit. The one on my notch took some
getting out.
I ended up getting a small plumbers style propane torch and applying a bit of gentle heat keeping in mind there are rubber bushes in there from
memory.(keep a fire ext. handy) you need plenty of leverage. smacking it with a hammer will just end up rounding out the inhex head.
[ Edited on 22-3-2006 by Stanley ]
Joel
| posted on March 22nd, 2006 at 08:48 PM |
on my 71 and 74 supers those bolts had 3 slots in the head which was supposed have the surrounding metal peened into them to stop them backing out
this maybe something to check
hth
Joel
1303Steve
| posted on March 22nd, 2006 at 09:42 PM |
Be very careful that you dont move the car off the stands when trying to undo them.
shaihulud
Threads: 197
| posted on March 25th, 2006 at 11:02 PM |
If Wd40 doesn't loosen it, try eucalyptus oil. It's the best penetrating oil that you can get.
BiX
Threads: 154
| posted on March 29th, 2006 at 03:32 PM |
or lanolin. It took me 2 weeks to get mine out the first time. drenching them with wd40 everyday. then used a breaker bar with extension, with gentle
taps from the hammer.
Go hard or go home!!!!
