[ Total Views: 801 | Total Replies: 3 | Thread Id: 50765 ]
Author: Subject:  wiper prob(they go past the rest spot)
Memberkombibob
Threads: 173
Mood: at by cows
mad.gif posted on April 9th, 2006 at 05:57 PM
hi all
just fitted my wipers back on the bay and when i tested them they go accross fine but return way past the rest spot(off the windscreen down the front)then back up to the original rest spot.
hope that makes sence
anyone know why???
1961 swb buggy
1960 karmann ghia
2012 Skoda Octavia scout
Get down low and go,go,go
MemberKombi_Rescue
Threads: 35
Mood: DSK member
posted on April 9th, 2006 at 06:17 PM
bob you will need to disconnect the rotor arm from the wiper motor allow the motor to park then refit the rotor arm to the motor in park spot..make sense...oh yer a couple of jd's helps cheers steve
http://www.frenzix.com/dsk/dskforumbanners/dskbannertemplatesteve.gif
MemberAnthiron
A.k.a.: Nicko McKay
The Baja Rejuvenation Begins
Threads: 310
posted on April 9th, 2006 at 06:18 PM
do they still have the same arc of distance accross the windscreen? ie: are they travveling an extra distance to go off the windscreen or are they not covering as much windscreen and making up for it by going off the screen and then back to rest?
1974 Chevrolet Luv
1970 MK2 Ford Cortina GT
MemberNigel
Threads: 7
posted on April 19th, 2006 at 12:16 AM
Windscreen wiper blades going off the screen, has nothing to do with the motor or the park positon!
Assuming you still have the standard installation with the original wiper linkage, it's likely to be wiper arms incorectly positioned on the wiper spindles or just possibly, excessively long wiper blades.
