[ Total Views: 859 | Total Replies: 1 | Thread Id: 51560 ]
Author: Subject:  Clutch disc...options.
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on April 30th, 2006 at 08:25 AM
What clutch disc would you guys recommend. I have a 215mm kombi pressure plate with increased clamp force, although just before I broke everytooth off second, the clutch was slipping slightly at high revvs. The car has about 250hp at the wheels.
Matt
Memberdangerous
Mood: 591
posted on April 30th, 2006 at 03:46 PM
I would not go any larger in clutch diameter.
If it was slipping then you need a better clutch, but make sure that the slippage was not due to some over-adjustment, due to a travel issue.
A clutch will slip only when it's torque capacity is exceeded.
This is why you can normally drive thru the slippage to a higher rpm level and the torque being lower at that point will have less slip.
Any how, only go to stronger clutch if you absolutely have to...perhaps just a freshen is all that you need.
The tranny also needs stronger gears, and probably a better blow-off valve to prevent boost spiking and thus torque spikes.
Originally posted by westi
That's mad Alan.
[ Queries: 40 ] [ PHP: 10.3% - SQL: 89.7% ]
