[ Total Views: 666 | Total Replies: 2 | Thread Id: 5162 ]
Author: Subject: Tacho Hookup
MemberQuickbug
Threads: 16
Mood: Plucked...
smile.gif posted on April 9th, 2003 at 03:42 PM
Tacho Hookup
Can anyone tell me in idiot speak how to hook up a tacho??
I have no diagrams, charts, etc, as the tacho was in an old car and then pulled out.
The only problem i can see is telling which wire is for what from the tacho itself.
Its a cheap universal unit for 4, 6, or 8cyl cars...
Membervwrallycar
A.k.a.: Andrew Rankin
Threads: 83
posted on April 9th, 2003 at 03:51 PM
there should only be 3 wires
red---positive
black---earth
and another which goes to the negative side of your coil
there may also be wires if it has a light which are simply positive and negative.
just hook the tacho positive to a positive which has power from when your ignition lights come on and the earth is self explanatory.
if you dont already have a wire from the front to the back try running a harness through the roof( that is where the interior light is)
Memberkombikim
A.k.a.: Kim
disfunctionally capable
Threads: 84
Mood: always bleary
posted on April 9th, 2003 at 05:03 PM
if it helps - wire that goes to the distributor side of the coil is usually green
& to the dash lights for illumination is usually white, this is the case on most Asian made tachos
so
red - ignition - powers the thing
black- earth
green-(generally) takes the ignition pulse to calibrate the signal
white (generally) just lights it up at night :D
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on April 9th, 2003 at 09:52 PM
On the Tacho in the Kombi There were four wires.
Red +
Black -
White (coil -ve)
Blue (light)
The one for the light was easy to distinguish as it went directly into a little bulb holder clipped in the back.
Memberjboy82
Threads: 7
Mood: I find that highly irrelevant.
posted on April 9th, 2003 at 11:13 PM
on mine it goes
red- battery +ve
black- ground
green- coil +ve terminal
white- speedo light terminal on fuse box(check the fuse box diagram in a car manual for your car)
The wire colours can vary with different brands...
MemberQuickbug
Threads: 16
Mood: Plucked...
posted on April 10th, 2003 at 11:38 AM
Ah - sounds very straight forward.
Thanks one and all!
:D
MemberRobo
Threads: 120
Mood: Oval madness
posted on June 1st, 2003 at 02:19 PM
Im hooking up a VDO tacho one of the old back light one's, there are some jumper switch's on the back 1-5 it say's on the fitting instructions to celect 2 for a four cylinder motor, should the button be up with all others down, or down with all others up, to be selected over the top of the switch's it says OPEN.
Rob....
[Edited on 1-6-2003 by Robo]
Boxer Power
