| [ Total Views: 1139 | Total Replies: 4 | Thread Id: 51965 ] |
butidontunderstand
Threads: 113
Mood:
| posted on May 9th, 2006 at 03:22 PM |
how would i fix this? (rust)
so what would i need to fix this myself? doesnt need to be pretty, just to pass pink slip
thanks, karina
[ Edited on 9-5-2006 by butidontunderstand ]
| Error |
| Error |
| Error |
53racer
Threads: 36
| posted on May 9th, 2006 at 07:57 PM |
i have abit of rust around that area on my bug, i merely removed the windows and took off the guard, cut back, primed and painted, then glass back
in.
DE-38-UG
1964 1200.
Beware the Wolfsburg.
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
| posted on May 9th, 2006 at 08:07 PM |
Yep - window out, cut out rust, weld in new piece, treat, prime, paint, put window back in.
Anything else would be half a job and promote more rust.
68AutoBug
| posted on May 9th, 2006 at 08:15 PM |
Once You start prodding with a screwdriver....
that could end in ONE Large Hole... or more.....
to get it passed.... wire brush the rust... very lightly...
hopefully You won;t end up with a hole.....
then use Auto two part repair Putty [called BOG]
and smooth it over the rusted parts...
let it dry... then sand it back with wet & dry paper [WET}
and then paint it as close a colour as You can get...
that will get it passed....
it does look nasty though....
You could end up with holes once You touch it....
best of Luck...
53racer
Threads: 36
| posted on May 10th, 2006 at 08:36 PM |
i personally dont like bog. only time ive used it was in my sigma cabrio creation in the frame tops caps.
if u wanna keep the car and not have to deal with the rust later id go for a weld piece as well.
but up to you what u want to do with it, and also ure budget.
[ Edited on 10-5-2006 by 53racer ]
DE-38-UG
1964 1200.
