| [ Total Views: 959 | Total Replies: 7 | Thread Id: 54215 ] |
oldnslo
Threads: 50
| posted on July 12th, 2006 at 07:43 PM |
remove tie rod ends from steering box
I am stripping down the front end of my 56 bug for painting. I got the steering rod ball joints off the stub axles but i cant get them off the
steering box end. Are these pressed in ,? will I need a puller to get them off? anyone had this problem?
68AutoBug
| posted on July 12th, 2006 at 10:03 PM |
From Memory...??
the shafts of the tie rod ends are tapered....
so a puller or hit with a hammer should do the trick....
and a bit of WD40....
I think I undid the nut until it was flush with the end of the shaft, then a hit with a hammer....
nuts are pretty soft too....
best of luck
Lee -- 68AutoBug --
blutopless2
DAMSLO
Threads: 187
| posted on July 13th, 2006 at 03:15 PM |
should only be held in by the nuts. once undone hit the stud with a hammer to release the rubber seal.
see.... air and water do mix
1974 1300
1997 MK3 Golf GL
2003 NB Cabrio
2012 Golf VI GTI
2014 Audi A4 Quattro
mscabrio
Cabriolet Queen
Threads: 142
| posted on July 13th, 2006 at 05:41 PM |
posted by blutopless2
Just watch your fingers ..... hey Rod?
oldnslo
Threads: 50
| posted on July 13th, 2006 at 06:32 PM |
Yeah they are tapered, the ends on the stub axles came off easily but these ones are bastards, might try heating them uo.
jnr356
Threads: 33
Mood: casual
| posted on July 13th, 2006 at 09:07 PM |
DO NOT HIT THEM WITH A HAMMER
use a tie rod /ball joint breaker(tool)
if you hit them with a hammer you will f@#k them
if you must hit them because you can't get the correct tool,hold a large hammer on one side of the "eyelet"
and hit the opposing side
HGFS
A.k.a.: Greg
Threads: 42
Theme: UltimaBB Pro Brown
Mood: OK, I guess?
| posted on July 22nd, 2006 at 12:04 AM |
If you are still having trouble you can borrow a balljoint separator that I've got, works a treat, I've used it on about 3 front ends now
Greg
1954 Oval long term project going nowhere
1958 Beetle drag car project
1959 Beetle project I need to sell one day
1969 Squareback
oldnslo
Threads: 50
| posted on July 24th, 2006 at 11:44 AM |
thanks Greg, will see how I go, will give you a call if i still have problems
