| [ Total Views: 1266 | Total Replies: 5 | Thread Id: 54669 ] |
killakornkobb
A.k.a.: Damien
where's that clutch?
Threads: 149
Mood: Pierced
| posted on July 25th, 2006 at 08:40 PM |
coolant warning light!!!
coolant warning light on at startup, with the coolant temp gauge up at the highest temp
after a few mins it somtimes turns off, other times stays on for the duration of my trip
my engine temp digital display never goes anywhere nasty, not over 100 degrees
my thermo fan is fucked, and i have removed it and replaced with a Porsche 996 thermofan. will wire up the new fan tomorrow.
the warning light problem was apparent with the old thermo fan hooked up and with a good fuse, removing the fuse didnt help, and removing the fan
hasnt altered the situation either.
i thought maybe it was doing it when the thermofan fuse was blown, but i'v proven that wrong.
the coolant levle is in the normal ranges . it isnt too low.
anyone, anyone?
Tagedeezee Heezy
johny rotten
| posted on July 25th, 2006 at 08:47 PM |
replace the low level sensor and the expansion tank.
[ Edited on 25-7-2006 by johny rotten ]
joshyd
Threads: 2
Mood: not bad
| posted on July 26th, 2006 at 08:35 PM |
what sort of car is it??
how was the old fan fucked? was it just not turning on? if so, the fan switch will be dead, a common problem.
oval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
| posted on July 26th, 2006 at 08:56 PM |
hahahaha 996 fan... had a spare one just lying around at work huh?
:kiss
[ Edited on 26-7-06 by oval TOFU ]
killakornkobb
A.k.a.: Damien
Threads: 149
Mood: Pierced
| posted on July 27th, 2006 at 06:19 PM |
mk 2 golf GTI
fucked fan was siezed, 15yrs old and just had enough.
yeah i was quoted $85 for a second hand one, but we got about 30 porsche ones just sitting around close to brand new.
was easy enough to weld some brackets on, and put it in hahah
works GREAT too! and cost $000.00
i think you were right about the low level sensor johnny, because it all got wet on the weekend when the expansion tank nearly exploded, but now it
has all dried out, and the warning light hasnt made an appearance for the last two days
Tagedeezee Heezy
zjm
Threads: 23
Mood: undecided
| posted on August 1st, 2006 at 08:27 PM |
my mk2 does the same generally once the car is warm if I turn the ignition off and back on it resets itself annoying the hell out of me
