[ Total Views: 1404 | Total Replies: 27 | Thread Id: 55285 ] |
seagull
Threads: 752
posted on August 14th, 2006 at 02:19 AM |
Att Boof / WES , clutch plate ?
Matt / WES
what brand of clutch plate are you using & its lasting
Wes your V6 punches out some good power so what do I ourder for the New Subaru project ?
I would like to get it from the usa as I need a few of them
seagull
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
posted on August 14th, 2006 at 08:51 AM |
Neil,
I use a stock 2L Sachs clutch plate. It has been really good. At first I had a no brand clutch from one of the cheaper VW shops. The Sachs cost nealy
3 times as much, but hasn't exploded like the cheap one did.
The cheap one is on the left. It survived nearly 6 months but died on it's first beach outing. It always felt cheap and had an incurable shudder
problem.
The one on the right is the sachs. Been going 3 years with no problems. Much smoother than the cheap brand. Being an offroader I steered away from
puck clutches as I wanted to have good control.
I use the standard Mazda V6 pressure plate. I had it measured by a clutch shop and I think it was about 1700lb.
gull
Threads: 34
posted on August 14th, 2006 at 02:37 PM |
Thanks Wes , I place an order for them then
Cheers neil
pete wood
posted on August 14th, 2006 at 03:46 PM |
I back wes on that. German clutches are very good. I've filled mine up with sand to the point where it was slipping and very unhappy. Dusted it out
and gave it a clean and it works good as new. That's tough as far as I'm concerned.
gull
Threads: 34
posted on August 14th, 2006 at 04:30 PM |
better than your ECU on a wet night !
pete wood
posted on August 14th, 2006 at 04:31 PM |
you can say that again...but please don't.
BTW, you haven't come across one have you? I wouldn't mind a spare if it's cheap.
gull
Threads: 34
posted on August 14th, 2006 at 05:57 PM |
ej22 was it ?
& a cheap bucket to keep the water out
pete wood
posted on August 14th, 2006 at 06:54 PM |
the code is 22611 AB511. It's an early dohc ej25.
seagull
Threads: 752
posted on August 15th, 2006 at 02:39 AM |
no mate simon needs one as well
boof2332
Threads: 120
Mood: Sympathetic
posted on August 15th, 2006 at 07:03 AM |
I will hold comment for 3 days.. I am sure that my 215.. clutch is german, and i have had it slipping for 3 weeks...since the dyno. Because of the
Splitty conversion, the hoist is occupied and as soon as it's finished, the beetle will be ripped apart for a week while I start tackling a
reasonable list of changes/improvements, that have come from dailydriving 500 km a week since I finished it.It might be fluid on the thing, although
smells pretty bad and slips then sort of catches itself..eventually.
Me thinks hotspots on the disc. I have slowly got more and more power from little changes and its pretty much at its best at present.. low boost and a
slipping clutch made 150kw at the wheels..with my first pressure plate there was 50 kw difference from the slipping clutch to the dyno figure.2
different dyno tuners say it should be 200kw at the wheels.
I am looking at new discs now, however the 200mm has heaps more options than the kombi one. Flick through vw trends and see what is advertised.
Matt
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
posted on August 15th, 2006 at 08:31 AM |
A bigger diameter will transmit more torque for the same pressure plate pressure. That's why I went with the 228mm 2L clutch.
If I had a EJ20T street car I would get a custom 228mm clutch plate made. A place up here does organic lining on one side and ceramic pucks on the
other side of the plate. Apparently it is the best of both worlds.
71EJVan
Threads: 23
posted on August 15th, 2006 at 10:05 AM |
I have a Kennedy 2100lb with a standard german clutch plate (200mm) with my EJ20T Kombi conversion. I went for the 200mm due to the options available
off the shelf. Time will tell how relaible the plate is.
Brendan
A VW for everyone!!
1972 1302 German Look
1971 Bay Panel with Subaru EJ20T
1970 Type 3 squareback in progress
1971 Type 3 notchback in progress
gull
Threads: 34
posted on August 15th, 2006 at 10:45 AM |
This is why I made the fly wheels in 200mm as there is a good selection of plates about .You guys as there with running cars so its best to get feed
back .
+ I know Matt would cain his ride as hard as I would mine .
I am flying in on the 21/8 Matt for a full week & would like to have a beer or two .
Seagull
Mojave
Threads: 3
posted on August 15th, 2006 at 03:17 PM |
Hi seagull
there is a place in perth called Idlewild Off Road that has 200mm Kennedy stage 1, 2 and 3 in stock along with puck clutchs. would be a lot cheaper
then getting them from the US.
Mike
gull
Threads: 34
posted on August 15th, 2006 at 06:55 PM |
Yes I know Chris >I order the stock from the USA , Seagull
He did not have the Time to deal with me today
gull
Threads: 34
posted on August 15th, 2006 at 07:01 PM |
Chris is building some cool rides out there a rock hopper truck & a very low split screen bus .
boof2332
Threads: 120
Mood: Sympathetic
posted on August 15th, 2006 at 11:05 PM |
Where are you staying???
Definetely hook up. We have a big fridge at the shed. Just got a streets icecream freezer for summer. All i need to put in now is the firemans pole.
The splitty has a seagull 200mm with a kennedy stage 3 that was rebuilt here and has about 850kg clamp force. Soo close to running, cannot wait to
show you guys the pics.
Wes, I didnt think you could fit a 228 in the beetle bell housing...you are probably talking 2 litre box anyway hey.
Matt
seagull
Threads: 752
posted on August 16th, 2006 at 01:46 AM |
Seven Hills ( some were around there ) ? not sure I have not got my details todate .
I will be borded after hours for 5 days
I have no idea if this is near you but I would be stoked to check out what your up to & drink your beers & go for a run in the bug ,impress the girls
ect .
cheers Neil
avwboy
Threads: 7
Mood: slammed
posted on August 16th, 2006 at 09:58 AM |
its close enough 2 him
" Australians against over accessorizing vw's "
gull
Threads: 34
posted on August 16th, 2006 at 10:19 AM |
ok sweet
VDUBXTC
posted on August 16th, 2006 at 06:30 PM |
Maybe if you quit continually bad mouthing his work to others and telling people your work is better then his
Maybe the guy might give you the time of day.
I'm not doubting you do great quality work Seagull but why the need to shit on people behind their backs is beyond me.
just my 2 cents to why he wasn't helpfull to you
He Has always been extreamly helpfull with anything i needed, parts, info , anything. has always been extreamly helpful with those i have passed on
his number too.
gull
Threads: 34
posted on August 16th, 2006 at 07:31 PM |
putting shit on Chris ?
He should of told me he had an issue with me when I was there .He did not & I did not think he was short with me in that way .
he was welding at the time & I did not think he had the shits on me for one second
yes he would be helpfull as your buying things from him
But thanks for telling me thats great news >I be sure to make this clear to Chris next time I see him
Jas you do not know what goes on over here in WA
You seem to think I am against the man , I have no idea why .I know you have not liked me from the start but I can live with that .
I am sure you know , you seem to with every thing
Seagull
O my welding is better by the way
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
posted on August 16th, 2006 at 08:56 PM |
Quote: | Originally
posted by boof2332
oh yeah, good point. I have a 2L box.
boof2332
Threads: 120
Mood: Sympathetic
posted on August 17th, 2006 at 08:22 AM |
It is as close as 10 minutes at the right time of day..I did dural to the Shell space station on epping rd at lane cove in 14 minutes last
night...clutch was makiing some odd noises at the top of its slip.. Still wasted a stock wrx, although that isnt saying much these days. I had a new
bmw 4.4 X5 last week for work and hosed off a clubsport on the hill into dural...was sort of more fun than winning in the bug! Cost $40 a day in
petrol...that was not fun!
Matt
seagull
Threads: 752
posted on August 20th, 2006 at 07:01 PM |
I give you a call when I get in Matt , cheers Neil
hotdog008
Threads: 8
posted on August 20th, 2006 at 08:00 PM |
i need to talk clutches to
in my manx with the ej20t it only used to slip on bitchumen as it came on boost in 3rd gear
on dirt in 3rd it would wheelspin on boost
now(a couple of months latter) it is slipping on boost in 2nd on the road and i think it is starting to slip on dirt in 2nd as well
it does not slip around town unless you hit boost
i have a 2lt box with a 200mm bellhousing and clutch
i need to stay 200mm to keep my adaptor kit
i put a new RPM clutch kit in (20% stronger than standard) that was from a 1600 kombi box
what do i need to stop it slipping?
what are 3 or 5 puck like on the street
1303Steve
posted on August 20th, 2006 at 11:56 PM |
In my WBX I 1st ran a stock 210, then a stock 215, then 228 which can be fitted into a Type 1 trans, but you really need to grind a lot of the bell
housing away to fit it in, then I had a specialy made 215 by Race Clutch in Qld, years ago it cost me about $600 to have it made up and if it needed
any work needed to be done to repair it I had to send it off to Qld and wait for it to come back.
I have a 200mm Stage 4 from V Force for the next car, I hope it will be OK
pete wood
posted on August 21st, 2006 at 09:18 AM |
Quote: | Originally
posted by hotdog008
I was talking clutches with someone the other day...can't remember who now....that's right, it was David777 and he was saying you can get a friction
plate that is 5 pucks on one side and standardish material on the other. Apparently it's the best of both worlds. I can't tell you what a puck
clutch is from my experience, but I have a mate with a 1600 rally car and he has one. He says it works really well to race with. But you can't slip
it at all. He has to be really careful putting the car on the trailer coz once you burn it even a little bit, it stuffed. So I don't know how you'd
go in traffic.
