| [ Total Views: 821 | Total Replies: 4 | Thread Id: 55608 ] |
guru
A.k.a.: Mr. Meaner
Mood: ...Jolly calm at the moment, but that could change in half a millisecond
| posted on August 23rd, 2006 at 04:43 PM |
t3 floorpan & karmman ghia body?
Has anyone done this, tried this, know someone that has tried this...?
I've been told t3's & kg's use the same floorpan. Is this true?
If so, what mods if any, are required for the suspension beam?
Any info would be of great value as my ghia would be a big step closer to completion.
VWCOOL
Threads: 235
Mood: happy to help
| posted on August 23rd, 2006 at 07:19 PM |
No, KG uses a Beetle pan/suspension with different floorpan halves.
Pay your debts, CxxT
guru
A.k.a.: Mr. Meaner
posted on August 23rd, 2006 at 10:10 PM |
I know suspension, steering, wheel base, track etc is the same & floorpan halves are the difference.
I have a standard linkpin with irs conversion pan currently underneath the body. I also have a balljoint irs pan to suit a beetle. I can buy & fit kg
pan halves easily. When i asked for a price i was told t3 & kg took the same pan halves.
This just got me thinking if i can use a t3 rolling pan, suspension height mods can be fast & easy, better torsion bars, better gear ratios, better
brakes.....it makes sence??
Or should i follow the crowd & do the norm!!
There must be someone out there who knows about this.
VWCOOL
Threads: 235
Mood: happy to help
| posted on August 23rd, 2006 at 10:33 PM |
posted by guru
Pan halves - may be true. I don't know. But I do know that the Type 3 rolling chassis will not fit under your KG, But it woudl be nice if it did, for
the reasons you mentioned!
[ Edited on 23-8-2006 by VWCOOL ]
karmen
Threads: 130
| posted on August 23rd, 2006 at 10:46 PM |
i seem to have such a thing
done by an olde teacher friend
if u e-mail me i can give u his ph nr and he can expalin it all better than me gettin under my sweet ride which is irs and l/p wid da disc brakes
man does it handle any pwr
is on 14" wheels so nice height
Karmen
56 oval resto 60 Cal KG
63 Baja 80 GLD parting
