[ Total Views: 858 | Total Replies: 2 | Thread Id: 55728 ]
Author: Subject:  Audi mag wheel mods?
Membercrazyfiggi
A.k.a.: Alex
Threads: 138
Mood: lost
posted on August 27th, 2006 at 12:37 PM
Hey everyone, i have a set of audi 17inch mags and need to enlarge the hole in the very center of each wheel by about 7mm. How can i do this? Where could i get it done in Sydney?
Thanks,
Alex.
Member76camper
Threads: 89
Mood: happy :-)
posted on August 27th, 2006 at 04:52 PM
was told can use a dremel?
Plenty of engineering outfits in brooky that will b able to help out.
Member71EJVan
Threads: 23
posted on August 28th, 2006 at 03:57 PM
Best way is to get it done on a lathe. 66-68mm I think. Or you could use a holesaw as long as you can locate the pilot drill with some sort of plate bolted to the back of the wheel. Remember some wheel balancing machines rely on the centre hub hole being true to be able to balance correctly. I would not use a dremmel.
Lathe is the way to go.
Brendan
A VW for everyone!!
1972 1302 German Look
1971 Bay Panel with Subaru EJ20T
1970 Type 3 squareback in progress
1971 Type 3 notchback in progress
http://i6.photobucket.com/albums/y208/GL1972/GL1972F3DKbanner.jpg
[ Queries: 40 ] [ PHP: 14.3% - SQL: 85.7% ]
