| [ Total Views: 2342 | Total Replies: 12 | Thread Id: 56126 ] |
Patriot
Threads: 1
posted on September 6th, 2006 at 11:49 AM |
Sound Deadening Project
G'day all. My first post on this forum. I am seeking advice on sound deadening my 76 Beetle [ with soft top, which makes it a special challenge.]
Would be interested in hearing from anyone who has gone down this path. My car is used daily so I am looking at a system which allows this. This
daily use probably rules out liquid type materials.
I guess most people start at the rear and work forwards? Has anyone seen any results on a particular brand/type suited to VWs?
My local installation favours either Dynamat or the Focal [French ] brand, which also happens to be the same as my speakers...
I would appreciate advice on wheel wells, doors, and the boot area in particular..
Cheers, Patriot. |
PUNCH_BUG
Threads: 7
| posted on September 6th, 2006 at 12:35 PM |
Mate I can recommend dynamat, its what is going into my car and I have used it in a number of custom installations. You can get it cheaper off ebay or
if your in the Perth area I can get it at a good price. Its also easy to apply, clean the metal, removing any dust and contaminants, and either stick
it straight on or use a heat gun for a better application. Use a whole sheet at a time or cut it into strips to make it easier to get into the tighter
places. Use it on the whole car within the cabin, floor pan, firewall, roof, and the main one being the doors. I wouldnt bother oustide of the cabin,
as its main purpose is to reduse pannel distortion from your stereo. (although under your rear decklid would help reduse engine noise to the outside,
but who cares.
Hope this helps.
Joel
| posted on September 6th, 2006 at 05:10 PM |
main thing in a convertable is not to use somthing that holds water
last vert a mate owned had had the carpets and seats removed and then everything had been coated with sound deadner
-Joel
Patriot
Threads: 1
| posted on September 7th, 2006 at 01:57 PM |
Thanks guys; doing some research I notice RAAMaudio gets big wraps on the US forums. I haven't found any Australian distributor for this product,
unfortunately. I recognise Dynamat of course but in the US at least it seems to have a reputation for being over-priced.
Also, is it the case that Windex is the product to use [ de-natured alcohol?] to clean the metal [ floor pan etc]? |
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
| posted on September 8th, 2006 at 11:23 PM |
i used dynamat in my bug and it worked a treat mate. heres the link to it mate
http://forums.aussieveedubbers.com/viewtopic.php?tid=30740
Patriot
Threads: 1
| posted on September 11th, 2006 at 11:16 AM |
Thanks Barls for that link. There's no doubt that Dynamat is good stuff, but it should be given the cost.
Seems to me there are few shortcuts in this area; you get what you pay for and it all gets pretty technical when you start researching sound
deadening.
At this stage I am looking at a combination of product to deaden the various frequencies; good ol' tar paint on the exterior of the floor pan and
inside the wheel arches; a butyl type mat throughout the interior on a bed of the cheaper aluminium foil and and Ensolite type product on top of the
mat. |
barls
Threads: 296
| posted on September 12th, 2006 at 03:56 AM |
i went with the undercar sound deadener on my pan, its the spray on type
76camper
Threads: 89
Mood: happy :-)
| posted on September 18th, 2006 at 04:10 PM |
barls, did the spray on deadener make much of a difference?
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on September 18th, 2006 at 07:45 PM |
I used cheaper Fusion sound deadener on the inside of the floor pan, then used both Stinger Roadkill and Dynamat in the doors, quarters and inside of
firewall....also in footwells - worked a treat and you are right in you get what you pay for.
barls
Threads: 296
| posted on September 19th, 2006 at 04:38 AM |
it made a bit of a difference but it was sprayed on both sides of the pan on mine
oval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
| posted on September 19th, 2006 at 12:57 PM |
I brushed on two coats under my pan. Only a slight difference. I think it more aimed at stone chip protection more than anything else.
fozee
Threads: 14
Mood: Inquisitive
| posted on October 11th, 2006 at 10:33 PM |
Dynamat is cheaper on Ebay, just do a product search.
Thats where ill be getting mine from
Over 200Kws of rear mounted 4ltr V8 Quad cam action.....
In a Bay
76camper
Threads: 89
Mood: happy :-)
| posted on October 13th, 2006 at 09:04 AM |
Im mainly aiming to increase panel weight (move vibration to inaudiable range) and stop my door cards rattling.
How would this stuff go?
6.35mm thick ,600mm wide,10meters long roll, 1 ply insertion.
| Error |
