[ Total Views: 710 | Total Replies: 4 | Thread Id: 5719 ]
Author: Subject: Head Bolt helicoils??
MemberAndy
Andy's Adventures
Threads: 181
Mood: Happy Man
posted on April 27th, 2003 at 08:33 PM
I've been asked if I want to buy a used and abused late type 3. I'm keen but owners 're-built' the motor himself (a real back yarder!!) and said the head bolts have been helicoiled crooked and then re-done. Is the block likely to be stuffed? As the motors not in, it’s never been run. (it has new P&C + bearings, and recon. heads).
Is it worth anything? I guess he’ll be asking a bit to recover the money spent on parts for the re-build.
[Edited on 27-4-2003 by Andy]
Member70AutoStik
Threads: 18
posted on April 27th, 2003 at 08:40 PM
They're usually referred to as "case-savers" in VW circles. If they were done crooked for 8mm studs, then re-done for 10mm, you should be OK. If they were just straightened up on the original size, you'll need a new case.
Membervwmachine
Threads: 0
Mood: shity
posted on April 28th, 2003 at 12:00 AM
you need a new case
see Vintage Vee Dub
MemberKruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
posted on April 28th, 2003 at 08:05 AM
I'd personally be offerring him a lesser amount under the assumption that the motor is not up to scratch. As for him trying to cover his costs, we all know that rarely works.
New case or replacement motor - chances are that he has stuffed up the current motor, but check Autostik's suggestion first, it makes sense. Be careful with backyard rebuilds, often a lot of stuff gets overlooked. Ask him if he owns a torque wrench! :)
Kruizin Kol
posted on April 28th, 2003 at 08:13 AM
Dont waste yr money, if yr engine needs are build then spend yr money on that.
MemberAndy
Andy's Adventures
Threads: 181
Mood: Happy Man
posted on April 28th, 2003 at 09:36 AM
Thanks for the advise. If the price is right I like the idea of adding a type 3 to the line up. I do have a spare type 1 case that could be used if it is not salvagable (I assume you can convert them?).
I'll see what he's after and do a closer look.
Andy
MemberKruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
posted on April 28th, 2003 at 05:15 PM
yeah they are the same thing, but check that the Beetle motor has the bolt holes for the Type 3's rear engine support bar to bolt to. Some of the earlier Beetle motors don't have the necessary holes. :)
Kruizin Kol
MemberAndy
Andy's Adventures
Threads: 181
Mood: Happy Man
posted on April 28th, 2003 at 05:45 PM
Thanks Col,
it's a 1600 twin port, so I should be OK.
Member70AutoStik
Threads: 18
posted on April 29th, 2003 at 08:48 PM
You might still need to add a couple of tapped holes, but it sounds like you could get a bunch of good parts (along with another car) for a decent price.
