| [ Total Views: 1638 | Total Replies: 20 | Thread Id: 57960 ] |
THUDKNUCKLE
A.k.a.: James Stoodley
Threads: 25
Mood: Crazy
| posted on October 29th, 2006 at 01:45 PM |
AXLE HOP WITH NEW GEARBOX please help :)
hey guys i am hoping someone an help me out with my lil situation i have
just completed a 6 rib kombi tranny bus converison in my baja a week ago and now i am getting some axle hop on take off ?? the old single side plate
box showed no sign of this at all and i have good strong engine and tranny mounts in place ( 13b Rotay)
[ Edited on 29/10/2006 by THUDKNUCKLE ]
Love is a Rotary baja bug
Just be carefull  ,, something dangerous is lurkin in My garage
ready to burst out in a fit of Big Hp, high boost baja Rage .
http://groups.msn.com/GottaVW
pete wood
| posted on October 29th, 2006 at 02:56 PM |
have you got decent shocks? also, could just be the low nature of the very low first gear....hold on just a second, have you got your bowden tube
installed right? it needs a decent kink in it or you'll get clutch shudder on takeoff. if it's not long enough you could pack it out with a few
washers, or alternatively, use a kombi bowden tube which is about 10mm longer. I had this problem and the kombi bowden tube fixed it. Also, if you
have a tranny strap, the bowden tube needs to go around the outside, not underneath.
kevo
A.k.a.: kevo Milner
Theme: UltimaBB Psyche Green
Mood: always happy
| posted on October 29th, 2006 at 03:34 PM |
my bus used to get that when i did standstill burnouts but i changed the rear shocks n it sits firm now
76 baywindow kombi - V8 & Weddle racing diff and gearbox
Daily driven beach cruiser
THUDKNUCKLE
Threads: 25
Mood: Crazy
| posted on October 29th, 2006 at 06:11 PM |
yes the shocks are new and didnt do it with the old gearbox as for the bowden tube i am unsure of what a bowden tube is or how mine is set up ?? this
may very well be the problem ??? thankyou look forward to finding out this bowden tube
regards james
Yogie
Threads: 108
| posted on October 29th, 2006 at 06:21 PM |
The bowden tube guides the clutch cable from the rear of the pan (where it exits) to the arm on your gearbox that you attach it to.
Yogie.
THUDKNUCKLE
Threads: 25
Mood: Crazy
| posted on October 29th, 2006 at 06:36 PM |
may i ask why will that will effect clutch shudder ?? and why the kink in the tube ?
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on October 29th, 2006 at 08:20 PM |
Read this...
http://www.vw-resource.com/bowden_tube.html
THUDKNUCKLE
Threads: 25
Mood: Crazy
| posted on October 30th, 2006 at 10:55 AM |
Thankyou baja wes that is awsome help as i am pretty sure my tube is straight
take care
pete wood
| posted on October 30th, 2006 at 01:37 PM |
no more shudder then?
Kimbo
Threads: 30
Mood: Is it beer O'Clock yet ?
| posted on October 30th, 2006 at 01:55 PM |
Mmm, so if I'm replacing the cable clutch with a hydraulic one, are there any "tricks", along these lines, that I need to be aware of ?
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on October 30th, 2006 at 02:29 PM |
leave a bend in the hydraulic hose to allow the gearbox to move without pulling the hose tight (and breaking it).
Kimbo
Threads: 30
| posted on October 30th, 2006 at 03:28 PM |
Thanks Wes - am going to use steel though to the end end of the frame, then braided hose to the slave cylinder anyway, but will allow a bit more slack
in any case.
Cheers .. Kim
THUDKNUCKLE
Threads: 25
Mood: Crazy
| posted on November 3rd, 2006 at 09:23 PM |
nope all shudder has gone but there is a lil bit in reverse thanks guys funny how a lil bend in a pipe can make all the differance
karmen
Threads: 130
| posted on November 3rd, 2006 at 09:36 PM |
it's the torque of the engine twistin itself and the box and if the tube is not stiff will affect smooth clutch operation.
so for a hydraulic i would not feed a rigid tube through the bracket (exbowdentube bracky)
the twistin may kink and weaken it thus shortening its life...
Karmen
56 oval resto 60 Cal KG
63 Baja 80 GLD parting
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on November 3rd, 2006 at 10:53 PM |
| Quote: | nope all shudder has
Where did you buy your clutch plate from, and what brand is it?
I had a little shudder in reverse only and couldn't get rid of it. I had a cheap no-brand clutch plate. Once it exploded I replaced it with a sachs
clutch, and the shudder went away.
THUDKNUCKLE
Threads: 25
Mood: Crazy
| posted on November 4th, 2006 at 06:17 AM |
my clutch including clutch plate was custom built by the fellas out at albion clutch works. it definatly isnt a cheapo clutch plate as it was the best
clutch and clutch plate they had on offer ( its 5 pad brass button model with thicker then stock pads) the shudder in reverse doesnt concern me to
much as it is very minimal and only occurs on first take of
OZ Towdster
A.k.a.: Andrew Westwood
Keen to finish some projects
Threads: 132
| posted on November 4th, 2006 at 07:37 AM |
Lets just say that with a BRASS BUTTON clutch plate it will NEVER be as smooth as a fibre clutch plate but that is not to say that i would change it
with the power you have with the rotary it will be one of those things to get use too.
THUDKNUCKLE
Threads: 25
Mood: Crazy
| posted on November 4th, 2006 at 09:27 AM |
yeah it is only in reverse though taking of is smooth with no shudder of jerking or clutch catching ( took a lil bit to get used to the weight of the
clutch though ) and changing gears is smooth and fine with no shudder or feel at all. i am thinking it is due to being reverse such a low gear.
[ Edited on 3/11/2006 by THUDKNUCKLE ]
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on November 5th, 2006 at 08:24 AM |
yeah, a brass button clutch will get those vibrations and be rougher compared to a stocker.
That's why I stuck with a stock 228mm sachs clutch plate. It doesn't slip and is very smooth.
rivmasta
Threads: 9
| posted on November 6th, 2006 at 11:43 AM |
posted by Kimbo
in any case.
Cheers .. Kim
Why bother with the steel line? Extra connections means more $$$ and more complications. We used a CNC Pull type slave cyl with braided line to a
3/4" PBR (cheapo!) master cyl. Never had a problem with it.
We still have it from the old car - I'll PM you.
You kids get off my lawn!!!
Kimbo
Threads: 30
| posted on November 7th, 2006 at 10:47 AM |
Thanks Garry
