[ Total Views: 1295 | Total Replies: 6 | Thread Id: 58170 ]
Author: Subject:  Show us ur BALLJOINT beam barwork mounts!!!
Memberbajachris88
A.k.a.: Chris Leete
Threads: 534
posted on November 3rd, 2006 at 12:13 PM
THinkin' of modding my K&L barwork to suit a ball joint front end... just need some inspiration to see how the ball joint ones properly fit.
cheers guys.
chris
(ô_!_/ô) (ô_!_/ô)
Memberbajachris88
A.k.a.: Chris Leete
Threads: 534
posted on November 3rd, 2006 at 10:07 PM
bump
(ô_!_/ô) (ô_!_/ô)
Membersubibaja
Threads: 45
posted on November 5th, 2006 at 10:32 PM
how does yours bolt on
show us
terry
anyone who says it's bad to put subaru motors in vw's.....
hasnt got a clue about smoooooooooth
terry
brisbane
0403252522
you know who i am
Memberbajachris88
A.k.a.: Chris Leete
Threads: 534
posted on November 5th, 2006 at 10:52 PM
these are the only pics i currently got, hope they might help...
my rear barwork too doesn't fit. its for swing axle, and won't fit my IRS suspension (the bars that mount onto the rear torsion tube doesn't clear my trailing arms)
this picture shows the front bar work, that bolts onto the torsion tube mounts...
(ô_!_/ô) (ô_!_/ô)
Memberbajachris88
A.k.a.: Chris Leete
Threads: 534
posted on November 5th, 2006 at 10:55 PM
These are hte mounts that go on the torsion bar tubes, and they also go back to mount of a pair of body bolts as well...
seems to mount pretty firmly (if on a K&L Of course)
(ô_!_/ô) (ô_!_/ô)
Membersubibaja
Threads: 45
posted on November 20th, 2006 at 10:13 PM
custom off road make the plates with the scollops in them to suit k,l or b\j beams
so you could buy them and simply cut them off and weld in b\j ones then cut the plate off the front bar and weld the bar to the front plate of the beam support .
with the rear you can buy an irs sub frame cage from custom off road they are slightly bent up so they clear the trailing arms
then cut yours to suit behind where it bolts onto the frame horns weld in some sandwhich plates and it will make your life sooooooo much easier when you have to remove your cage (and you will have to remove it more than you think)
terry
terry
brisbane
0403252522
you know who i am
Memberbajachris88
A.k.a.: Chris Leete
Threads: 534
posted on November 20th, 2006 at 10:18 PM
Thanx terry, thats a big help.
Looks like i will be getting in contact with ya at COR shortly.
cheers mate
:thumb
(ô_!_/ô) (ô_!_/ô)
[ Queries: 40 ] [ PHP: 21.8% - SQL: 78.2% ]
