[ Total Views: 1756 | Total Replies: 8 | Thread Id: 59040 ]
Author: Subject:  Shortened Sump
Super AdministratorMISS VDUB
A.k.a.: Ash
Mrs KOMBIBOB
Threads: 96
Mood: Low down and Dirty
rsvdclap.gif posted on December 22nd, 2006 at 06:32 PM
Shortened Sump
Ok guys, it's Sump shortening time for me!
I was wondering if you could help me out with some pictures of the shortened sumps you guys have on your conversions?
Thanks in Advance!
Ash x
1962 Baja Beetle: "Peanut"
1968 Porsche 912 SWB: "Pip"
1972 Kombi Snail: "The Snail"
2016 Scirocco R: "Rocco"
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on December 22nd, 2006 at 07:10 PM
Direct from Custom off road
A.k.a.: Ash
Mrs KOMBIBOB
Threads: 96
posted on December 22nd, 2006 at 07:37 PM
Thanks Pete, yeah i checked out the COR Sump on their site, but was curious to what other people have done themselves, and how it turned out?
Ash x
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on December 22nd, 2006 at 09:45 PM
some here Ash....
http://forums.aussieveedubbers.com/viewtopic.php?tid=40369
:smilegrin:
posted on December 23rd, 2006 at 12:31 PM
boof does a good one. my sump is actually still stock.
A.k.a.: Ash
Mrs KOMBIBOB
Threads: 96
posted on December 23rd, 2006 at 09:10 PM
My sump sits quite close to the ground and definitely needs shortening.
Ash x
Memberphatratpat
Threads: 26
posted on December 23rd, 2006 at 10:58 PM
:rolleyes: { thinks to self....do,es this motor make my sump look big ? }
DAM I gotta stop drinking !!!:no:
Memberseagull
Threads: 752
posted on December 24th, 2006 at 12:21 AM
yes how is Matts going ? give us a look big fella
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on December 24th, 2006 at 07:05 AM
I'll get a photo of one I have...Paul popped in the other day and we just cut 25mm off the bottom of his and weldded a 3mm skid plate. We then welded the original drain plug back on. Thats what Paul wanted as it was quick, cheap and you still use about the same amount oil, just fills up a touch more....
The one I can make now uses one piece of steel to make the bottom and front side, I then bend the other 3 sides out of a piece of sheet and weld that in. The top plate is profile cut for perfect fit and welded on top. Its bigger than the first one we made..
Matt
[ Queries: 40 ] [ PHP: 13.7% - SQL: 86.3% ]
