| [ Total Views: 1464 | Total Replies: 12 | Thread Id: 59205 ] |
seagull
Threads: 752
| posted on December 31st, 2006 at 12:21 PM |
Not vw Nissan S13 > SR20 det black top
I am working on my S13 silvia & fitting a 180SX SR20 DET black top in it for next years speed events
Is any one up to speed on the wiring ? I would like to know if I need to swap the dash loom over or can I graft the stock loom to the 180 sx loom
links to some fourm ect would be great
seagull
1916
| posted on January 1st, 2007 at 11:01 PM |
http://www.nissansilvia.com is probably your best bet neil.
"what kinda creator would make a race of people
and make em act a certain way or else He deems 'em evil?
HOW can You give a living being the freedom to breathe
and then lead em into a sea of decievers who greet em, see!"
seagull
Threads: 752
| posted on January 1st, 2007 at 11:58 PM |
full of 16 >18 years olds full of ice cream & know poo about any thing but checker plate floor mats
bajaben
A.k.a.: Ben Alderson
Threads: 33
Mood: need more power
| posted on January 2nd, 2007 at 02:02 AM |
not 100% sure but the looms should be the same as the car is the same pretty much, both the silvia and 180sx are s13s the original 200sx is an s14 and
the new silvia and 200sx are s15. but i still think all the engines are basically the same all the way through, should be a bolt in swap as far as i
know.
trunk monkey, because sometime getting your car back just isn't enough
1916
| posted on January 2nd, 2007 at 05:18 PM |
yeah i also agree with bajaben. silvia/180sx should be same as long as they were both sr20 to start with.
some silvias are ca18
13BVW
Threads: 6
Mood: always chilled
| posted on January 2nd, 2007 at 09:01 PM |
dont know if all wiring looms are the same have spent the last 2 weeks fitting a s15 vvt sr to my 180b sss as long as you have the engine loom you
should be right i think thats all that differs between models ypu could try perfomance forums ther are a lot of nissan boys on there
13BVW 11.80@114mph
seagull
Threads: 752
| posted on January 3rd, 2007 at 01:00 AM |
I dont mind taking my time on this as I have removed a lot of items I dont need .
wow a VVT very nice .I must stop building * other cars * & get back to my dub
john1960
Threads: 14
| posted on January 3rd, 2007 at 08:14 PM |
posted by 13BVW
john1960
Threads: 14
| posted on January 3rd, 2007 at 08:21 PM |
Have Just put a NissanL20b single carbie motor in my 1976 microbus do u no what sort of fuel ecconomy i should expect?? Motor is fully rebuilt, tuned
& running spot on. At 100kph it was revving at 4000rpm, to reduce this i am putting on 15" merc rims with 205/70/15 tyres. Am hoping on good fuel
eccomomy!! The extra power is good. John 1960
john1960
Threads: 14
| posted on January 3rd, 2007 at 08:23 PM |
posted by 13BVW
seagull
Threads: 752
| posted on January 3rd, 2007 at 10:37 PM |
John I recall you calling me the other day regarding this .
Wes has a speed program I think in this section ? But the main problem is the RPM your doing with that gear box , the motors max RPM is around 5>6
tops ?
you would be changing the gear box ratio , give the rims a go
you have a 1600 gear box ??
john1960
Threads: 14
| posted on January 4th, 2007 at 08:59 PM |
Seagull
With my nissan L20B conversion i have a 2 ltr gear box. Putting 15 inch rims and tyres on tomorrow. Hoping this will make a difference with the revs
and thus a difference with the fuel economy. Any advice to get good fuel economy would be appreciated. the extra power comparied to my old 2L VW motor
is great. Thanks John
seagull
Threads: 752
| posted on January 5th, 2007 at 01:18 AM |
apart from a boger od wheel set up the only other things that come to mind is
get aother carbi
get a holden camira single point fuel injection system on it from a 2ltr
change the cam if it has a hot fuel drinking one
LPG system
dont drive it Just tell every one it goes great & cheap to run
This motor is very old you may only know about old school donks ,but look around the subaru ej22 would be the best on the conversion table IMO , these
are getting old now & the EJ25 is coming through but these have some head issues
I have not seen any one jump up about there EJ25 fitment in a vw
EJ25 in a subaru turbo , well they go very hard
