[ Total Views: 1106 | Total Replies: 6 | Thread Id: 60207 ]
Author: Subject:  Cam and Crank sensors..seagull
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on February 5th, 2007 at 10:03 PM
I have just put my cam and crank angle sensors in the splitty as it was dropping 600rpm for no reason with no regularity. Problem solved..put mine in. Anyone got a couple of spares?
Matt
Memberseagull
Threads: 752
posted on February 6th, 2007 at 01:36 AM
I will have a look this weekend ( having a clean out )
really I am making room for the STI motor :)
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on February 6th, 2007 at 10:12 PM
I'm sure you are, till you decide there is a better option...still need to get rid of all the recently made obsolete options to make room for the latest idea.
Matt
MemberturboL
Threads: 14
Mood: building
posted on February 27th, 2007 at 02:54 PM
ECUS
Hey what sort of ecus are you guys running,My turbo L bug is coming together so have to start organiseing how,what, where and what brand set up Im going to use,also anytips on base set up of sensors,im running a typr 1 motor MSD dissy dual throttle bodies ,so I know I will need minimum of crank angle ,map ,cyl head temp,, Im not sure about O2 lamda bizzo,I fgure you guys run factory ecus but any insights would be much appreciated cheers JS
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on February 27th, 2007 at 09:06 PM
Matt
great ideas...........just poorly executed !!
Memberseagull
Threads: 752
posted on February 27th, 2007 at 09:26 PM
autronics in my machine
thats the bug & the V3 STI
Memberseagull
Threads: 752
O the S13 black top with the air flow unit is stock :)
[ Edited on 27-2-07 by seagull ]
[ Queries: 40 ] [ PHP: 11.7% - SQL: 88.3% ]
