| [ Total Views: 1790 | Total Replies: 16 | Thread Id: 60706 ] |
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on February 22nd, 2007 at 08:25 PM |
What would be the quickest N/a 1916cc 1/4 mile time in Aus ??
SO what is a quick time for a N/a 1916 beetle down the quarter ???
I would prefer to know times from street reg cars or at least cars that would be street registerable.................................Like a Dave
Becker style of car!
And HP if you know !
Craig T
THUDKNUCKLE
A.k.a.: James Stoodley
Threads: 25
Mood: Crazy
| posted on February 22nd, 2007 at 09:21 PM |
sounds like an interesting topic if we can get some info
Love is a Rotary baja bug
Just be carefull  ,, something dangerous is lurkin in My garage
ready to burst out in a fit of Big Hp, high boost baja Rage .
http://groups.msn.com/GottaVW
westi
what the
Threads: 28
Mood: not blue, pink
| posted on February 22nd, 2007 at 11:03 PM |
my wifes old beetle had run 14 flat,
my mates 1916 ran 13.2
these were run at eastern creek (old track)
many many moon's ago
down sharon.
Boostn
Threads: 28
| posted on February 22nd, 2007 at 11:56 PM |
Mark Gottwalt with an 1835 over 10-15 years ago ran 13.7
does it count, it's only 2mm on the bore. LOL
VOLLKOMMEN ART
nick@vollkommenart.com
Speed and Style
fullnoise
Threads: 103
Mood: Middle of the road.
| posted on February 23rd, 2007 at 12:39 PM |
14.9 is my best so far but I can see it getting down to the 14.5 mark with the new gearbox.
What does your dunga do Craig?
esratrams
bus914
Threads: 233
Mood: Could be worse
| posted on February 23rd, 2007 at 12:48 PM |
if it must be na, then probably one running OzNOS.
Craig Torrens
Threads: 347
| posted on February 23rd, 2007 at 04:10 PM |
posted by fullnoise
I've never run the 1/4 only the 1/8th.....and that was 8.74
So is 13.2 that westi mentioned the best ?
[ Edited on 24-2-07 by Craig Torrens ]
reub
VWRX is gone...
| posted on February 24th, 2007 at 07:50 AM |
It would also be interesting to know the specs of these engines, C/R's etc.
Reub
dangerous
Mood: 591
| posted on February 24th, 2007 at 10:34 AM |
posted by Craig Torrens
So is 13.2 the best ?
=13.68
http://wallaceracing.com/8th-quarter-conversion.php
Is this with stock gears Craig?
The most power I know of from 1915(not 1916) is about 150 at the flywheel.
But the owner thinks Dragracing is "unrefined" so we will never know how fast it is.
I know of four sub 1915cc cars that have gone better than mid 12s,but are not street registered.
Could they drive on the street?
Yes.
Are they legal?
No...unless methanol or C14 is now legal.
With the current Off-the Shelf CNC heads that are now available,
high 12s in a car like Dave Becker's should be quite acheivable,
on radials and pump fuel.
posted by westi
That's mad Alan.
Craig Torrens
Threads: 347
| posted on February 24th, 2007 at 10:44 AM |
150hp at flywheel= 120hp at the wheels ??
Dave that was in my hillclimb car with the hillclimb box...........ratio's were not stock, can't remember what they are.
So you think high 12's would be possible?
dangerous
Mood: 591
| posted on February 24th, 2007 at 03:23 PM |
Without doing the maths I would say that 150fw would be about 130@wheels and in 800kg car with driver COULD run in the 12's @100mph.
MPH is directly related to HP and mass,
whereas ET is a combination of gears, traction and driver.
The dyno I went to had 14 percent reduction from FW to RW.
Dynos vary as do their correction factors.
That looks like some big pipes their Reub', can you put some verniers on the OD for me?
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on February 24th, 2007 at 03:33 PM |
I did the maths at 800kg(1760lbs) and 150hp is 103mph.
From the dyno I went to it would be around 129hp at the tyres corrected.
posted by westi
That's mad Alan.
Craig Torrens
Threads: 347
| posted on February 24th, 2007 at 03:49 PM |
Wow the theoretical time sounds good ......................just need to find out what REAL times have been done.
Is it possible to get a 69 1500 swinger down to 700kg, keeping it looking original/stock (No fibreglass etc) and street legal?
Kai.A.
Mood: dubless...
| posted on February 24th, 2007 at 03:52 PM |
gut it.
swap the side and rear glass for plastic.
you might have done this already....
kai
Craig Torrens
Threads: 347
| posted on February 24th, 2007 at 03:55 PM |
The car is stock standard at the moment, full interior etc.........
Craig Torrens
Threads: 347
| posted on February 27th, 2007 at 09:10 PM |
Any more recorded times?
13.2 is the best so far............
westi
what the
Threads: 28
| posted on March 1st, 2007 at 11:31 PM |
flywheel and clutch 7.9 kilo's
044 with 44inlet 37.5 ext .heads flowed 176cfm @600' lift
gb315 b cam with ratio rockers
14to 1 comp (pump fuel + 3 bottles of octane booster to stop the pinging)
magna dizzy modify to fit
counter weight crank and rods were pobjoy item's
engine was like a good dos of viagra it lasted for 8 hours. and it would pull a soldier of your sister.
dyno hp 122.7 @ the wheels
after three weeks of 9000 rpm punishment and thrownig around 2 to 3 fan belts per day ,two gearboxs 3 clutches and a partrigde in a pear tree.it
wouldn't pull skin of your warm custard.
down sharon.
