| [ Total Views: 1456 | Total Replies: 8 | Thread Id: 61105 ] |
Anthiron
A.k.a.: Nicko McKay
The Baja Rejuvenation Begins
Threads: 310
| posted on March 14th, 2007 at 10:12 AM |
long tie rod contacts the tunnel on full droop.
my long tie rod contacts the tunnel on full droop of ym front susupension now with the cut and turned beam in there.
so i just want to tap a bit of a dent into the tunnel so it wont touch.
what do u guys think of this method?
can i just take the long tie rod off and the fuel tank out and do this?
Nicko
1974 Chevrolet Luv
1970 MK2 Ford Cortina GT
mattie182
Threads: 108
Mood: Buggy On
| posted on March 14th, 2007 at 12:01 PM |
generally, If you cut the tunnel along the same angle as the tie rod, and weld in a half a peice of pipe, this should work.
Ill try to get a picture to explain better
Once you go flat, you never go back!!!!!!
MickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
| posted on March 14th, 2007 at 12:26 PM |
| Error |
tssnq.com.au
Anthiron
A.k.a.: Nicko McKay
Threads: 310
| posted on March 14th, 2007 at 10:08 PM |
hmm thats gonna be a big job, i cant weld
1974 Chevrolet Luv
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
| posted on March 14th, 2007 at 10:33 PM |
Its a double panel there......will take a bloody big hammer to make a dent
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
subibaja
Threads: 45
| posted on March 17th, 2007 at 10:18 AM |
do it properly man
it doesnt take that long find some one to weld it in for you
anyone who says it's bad to put subaru motors in vw's.....
hasnt got a clue about smoooooooooth
terry
brisbane
0403252522
you know who i am
64vwmark
A.k.a.: Mark Shepherd
Threads: 82
| posted on March 18th, 2007 at 08:40 AM |
If you are successful in making a dent you may end up distorting the shape of the frame head which may put your beam out of alignment. I think welding
it is the only way to go.
Beach Buggy
74 L Beetle
Mk4 Golf
Brad
Threads: 332
Mood: Manx Buggy Building
| posted on March 18th, 2007 at 11:39 AM |
Cut and weld in the car drive in / drive out $275 as a guide to how much of a job it is. Only possible extra is some new fuel line and a tie rod end
or two, leading to a wheel alignment.
To bash the frame head you are going to have to pull the tank and everything anyway.
Tie rod hitting the frame head will give you bump steer and break your tie rod end over time.
makntracks
Threads: 10
| posted on April 5th, 2007 at 10:40 AM |
do it properly.
the last thing you want to happen when your up the beach is your tie rod end to snap off and then have to trailer it home.
69 baja soft top 1600 tp.(painting)
71 superbug(striped going german look eventualy after baja)
