| [ Total Views: 589 | Total Replies: 9 | Thread Id: 6298 ] |
Unity-28
TOO LOW? NEVER
Threads: 146
Mood: Tucked In nicely!
posted on May 12th, 2003 at 04:25 PM |
Keep cutting out!!!
Hi all! Of late, as I have been driving, Sometimes the car will just turn off as I am going along! Ive noticed that it is only when I turn my lights
on, and happens like once a week! for the past couple of weeks! I had a new generator fitted about 21/2 months ago and b4 that it never did it! Any
suggestions about what it could be? Ignition barrel maybe?
TY in advance! N!
mnsKmobi
Threads: 27
| posted on May 13th, 2003 at 12:01 PM |
Does it happen every time you turn your lights on? Does the engine restart with the momentum of the car or do you have to pull over?
Unity-28
TOO LOW? NEVER
Threads: 146
| posted on May 13th, 2003 at 12:52 PM |
Nah, I drive quite a bit at night, only every so often! Its Auto so I have to pull over, And It really strugles to start after that, as in not much
charge!
Cheers N!
Bizarre
| posted on May 13th, 2003 at 06:46 PM |
Sounding like a dud generator or regulator.
Is your generator light coming on?
How is your battery?
Maybe a short in the battery. When you turn lights on you are drawing off battery not genny and she dies? :jesus
Unity-28
TOO LOW? NEVER
Threads: 146
| posted on May 14th, 2003 at 10:31 AM |
Battery is fine, Its real weird! No generator light comes on. Nothing! I am taking it back to the guy who put the generator in, see what he says!
TY N!
Bizarre
| posted on May 14th, 2003 at 11:10 AM |
Does the gen light work at all?
Unity-28
TOO LOW? NEVER
Threads: 146
| posted on May 14th, 2003 at 12:05 PM |
gen light works!
geodon
Threads: 63
Mood: stumbling
| posted on May 15th, 2003 at 05:55 PM |
I'd like to see what a voltmeter accross the genny shows with lights off then lights on. It doesn't need much "juice" to keep the
warning light out.
New one on me & I'd love to hear the outcome & I hope it's not too expensive!
Jo Mama
Threads: 21
| posted on May 15th, 2003 at 09:18 PM |
Have you changed your coil recently? Sounds like the coil is getting too hot after driving for awhile. Does it also stumble or backfire before
cutting out?
vw_carrera
Threads: 32
Mood: wotif google was wrong???
| posted on May 15th, 2003 at 09:27 PM |
sounds like it could be a short somewhere
:alien |
OvalGlen
Threads: 46
Mood: Change
| posted on May 15th, 2003 at 09:52 PM |
be good if you could attach a Volt meter to the battery even if just temporary (muti meter ) to see what is happening to the Voltage.
Regards,Glenn>
Unity-28
TOO LOW? NEVER
Threads: 146
| posted on May 16th, 2003 at 10:42 AM |
Yeah, my thoughts were that the coil is stuffed, And it usually is after a while of driving, But when I changed the generator, the auto elec told me
everything else was fine! IT doesnt splatter b4 cutting out, it just does it!
Thanks all! N!
Unity-28
TOO LOW? NEVER
Threads: 146
| posted on May 23rd, 2003 at 10:28 AM |
It was the bloody DIzzy! That was stuffed, in turn killed my battery so The damage was $300. New Dizzy, Flasher can, Battery, Coil, and a couple of
bulbs!
Thanks all for any info!
N!
