[ Total Views: 3566 | Total Replies: 11 | Thread Id: 64579 ] |
rob53
Threads: 62
posted on August 25th, 2007 at 05:57 PM |
Powder Coating standard rims
I got a set of standard 4 stud rims that need some work. I was thinking of getting them sand blasted, and powder coated in silver. Anyone done this
before?
Looking for any words of wisdom, and if anyone knows of a place in the Bankstown area, or leichhardt area.
Rob
Thats not rust, it's ah ... orange primer ... yep that's what it is ...
pod
A.k.a.: paul mrvw061
Mood: could be better
posted on August 25th, 2007 at 06:04 PM |
isnt there a powder coaters near bankstown airport ??
blutopless2
DAMSLO
Threads: 187
posted on August 25th, 2007 at 08:01 PM |
shouldn't be a problem with doing them... if you do the sandblasting yourself just make sure you get them completely clean.
the powdercoater i have used several times (sorry he's in vic) just asks that i give the stuff to him asap after sandblasting so that it doesn't
start to rust....
oh.. and DONT touch it with your hands after sandblasting. rust will start to occur VERY rapidly if you do.
should be pretty cheap too...
see.... air and water do mix
1974 1300
1997 MK3 Golf GL
2003 NB Cabrio
2012 Golf VI GTI
2014 Audi A4 Quattro
rob53
Threads: 62
posted on August 26th, 2007 at 05:48 PM |
I done a search in yellow pages, and I think I found the one near the airport. But I also found 3 other places near me also!
I will try to find a place that does sandblasting as well to minimise handling. I never realised that touching bare steel would cause it to rust
faster.
Now I am starting to wonder about the repairs I done on my car a while back ...
Thanks for the advice Paul & Damslo.
[ Edited on 26-8-2007 by rob53 ]
blutopless2
DAMSLO
Threads: 187
posted on August 26th, 2007 at 09:28 PM |
i never gave it much thought until i did some powdercoating a while back... when they told me not to handle it i was a bit doubtful it could make that
much difference...
so did a test on some of the stuff i had...
sandblasted two items... one i left untouched by hands and the other i picked up with bare hands.
within about 30 minutes the one i touched you could see my fingerprints beginning to appear as rust spots... the other piece had no marks or rust
spots on it...
even without touching the pieces you should get some sort of coating on them as soon as you can.
1974 1300
1997 MK3 Golf GL
2003 NB Cabrio
2012 Golf VI GTI
rob53
Threads: 62
posted on August 28th, 2007 at 09:31 AM |
That's good to know, thanks blutopless2
PurpleT3
Threads: 55
Mood: knackered
posted on August 28th, 2007 at 09:57 AM |
Most paint specifications will state that painting must take place within 4 hours of blasting. You should definitley not touch blasted steel as the
acids in the fingerprints will speed corrosion, not to mention the oil will have to be removed before painting. I imagine the same thing applies to
powder coating.
bond
Threads: 166
posted on August 28th, 2007 at 12:47 PM |
usually powdercoaters will sandblast and etch prime for you prior to powdercoating.
nick
rob53
Threads: 62
posted on August 28th, 2007 at 02:00 PM |
I called one place and they are offering undercoating at an extra $15 per wheel. They said it would help to reduce rust. Should I dish out the extra
money?
StenGuns
Threads: 236
posted on August 28th, 2007 at 05:00 PM |
Rob.. There is a place in Gow St Padstow.. Seriously don't go anywhere else.. They have done a lot for me and their work and prices are 1st class..
You will get a bead or sandblast, etch prime, and a decent powder coat for about 30-40 buck per wheel.. If you're talking steel wheels probably
less..
Speak to Vanessa or Antony
Mr Clean Blast & Coat PadstowU 3/ 89 Gow St Padstow 2211(02) 9790 1998
rob53
Threads: 62
posted on August 28th, 2007 at 05:10 PM |
Thanks StenGuns,
That was the place I called! They were very helpful over the phone so I will definitely go there.
StenGuns
Threads: 236
posted on August 28th, 2007 at 05:13 PM |
Cool
