[ Total Views: 1556 | Total Replies: 2 | Thread Id: 64662 ]
Author: Subject:  bug studs
MemberTurkeyss
Threads: 55
posted on August 28th, 2007 at 07:09 PM
bug studs
hello, is anyone able to tell me the wheel stud pattern for the bug over the years? is a superbug 4 stud? how easy/ expensive is a conversion? is it simply just sliding on a special plate in between the wheel and hub? cheers
Super Administratorbarls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
posted on August 28th, 2007 at 08:18 PM
sbugs are 4 studs early bugs have wide 5
it depends on what you want to do the correct way is to get the discs and drums re drilled in the correct pattern but most times its a better option to go new discs and drums with the stud pattern you want in it. there are adaptor plates but they require engineers reports to be legal
the chaos project - click me
MemberTurkeyss
Threads: 55
posted on September 2nd, 2007 at 09:35 PM
awesome. thanks for da help, cheers
[ Queries: 40 ] [ PHP: 15.0% - SQL: 85.0% ]
