| [ Total Views: 556 | Total Replies: 3 | Thread Id: 6540 ] |
Sick68VW
Threads: 122
Mood: hearing 48s
| posted on May 18th, 2003 at 07:09 PM |
movement in my ball joint front end
hey all just wondering if any one has any opions on why the top arms have play in them mainy on full lock im pretty sure its the bearings
kafer70
Threads:
| posted on May 18th, 2003 at 07:19 PM |
also check the locating screw that goes thru the trailing arm and locates into the torsion leaves I've had mine come loose. |
vw54
| posted on May 18th, 2003 at 07:31 PM |
YES it sounds like the locating screw that hold the torsion springs into place are loose.
Loosen bothe sides off and re tighten making sure that the conical point on the screw goes into and locates the spring into the tube.
this is quite common on Type 3s for some strange reason but aint seen in on a Beetle. Always a first time
Sick68VW
Threads: 122
Mood: hearing 48s
| posted on May 18th, 2003 at 09:31 PM |
i have tryed retighting and still play unless i havent fitted them right
70AutoStik
Threads: 18
| posted on May 18th, 2003 at 10:30 PM |
Hard to say without getting it on a hoist and having a wiggle - but I would expect bearings to have an effect at any angle. More likely you're
looking at the ball joints themselves, or the torsion leaf screw...
vw54
| posted on May 19th, 2003 at 08:50 AM |
Are you talking / looking at the same think as me ???
70AutoStik
Threads: 18
| posted on May 19th, 2003 at 09:11 PM |
Yes, I can't remember the correct name for it either...
