[ Total Views: 1215 | Total Replies: 6 | Thread Id: 66471 ]
Author: Subject:  Fuel Tank mishaps
MemberIwish4aSynchro
Threads: 102
Mood: Cheery
posted on December 8th, 2007 at 04:24 PM
Fuel Tank mishaps
Hey Crew.
What is the asiest way to fix four small holes ranging from 1mm-4mm round?
Bought one of those fuel tank/radiator repair kits (dotheywor?k) but waiting on the fuel to evaporate from tank.(allDay)
Can i get it silver soldered while it is still on the car?
Options???
Ahh yeh how does one remove the inner drive shaft cap; the one behind the plastic cover?
While i was sussing the speedo cable this morning(exit hole in cap has slop) i noticed a shine on the fuel tank? Thats it; thats how it all started.....
What a day.....
Andrew
Keep the steering and the propulsion seperate . Still a Kombi...
It's all good, until it's bad, i suppose
Threads: 102
Mood: Cheery
posted on December 9th, 2007 at 08:14 PM
OK so not sure if those fuel tank repair kits work yet.
But that inner drive shaft flange aint comin out in a hurry with a puller of sorts.
Memberblutopless2
DAMSLO
Threads: 187
posted on December 10th, 2007 at 10:21 AM
easier to get it soldered whilst off the car... as you may have to clean some solder out of the tank afterwards.
make sure you clean the tank really well to get the petrol residue out.. i washed mine out several times and let it dry for a few days before getting some welding and soldering done on it.
1974 1300
1997 MK3 Golf GL
2003 NB Cabrio
2012 Golf VI GTI
2014 Audi A4 Quattro
Membergarycookson
posted on December 10th, 2007 at 12:51 PM
Is this your syncro? Dropping the tank is a transmission out job I believe. Roadworthy guy reckons mine has a leak but i can't find one. It's in being worked over at the moment. I'm praying there is no leak.
My tank is plastic too.
Gary
Memberblutopless2
DAMSLO
Threads: 187
posted on December 10th, 2007 at 02:04 PM
should have mentioned in my post that i did an early beetle.. so all steel tank.
dont know what's in the later cars as have never had to remove one.
1974 1300
1997 MK3 Golf GL
2003 NB Cabrio
2012 Golf VI GTI
Threads: 102
Mood: Cheery
posted on December 11th, 2007 at 07:55 PM
NAH not Syncro daily driver, Caravelle. So heres my resolution drained tank , dried tank 2days, used petrol/rad fix kit local servo sort of like liquid steel. Then after 12 hrs of setting, too make sure i added a thick layer of Arayldite(spellcheck). Seems to have stopped the leak even if it is for a short time just need to get chrissi out of the way. Yes Arayldite will eventually be eaten away. Remembered this trick with an old bultaco i owned after cracking the throttle cable cap off top off carbi and that one lasted for 3months.
Heres hoping
Plastic tanks dont leak/crack unless they are left dry for some time and then become brittle. Now thats a job. Ahh the joys of syncro ownership; i have now put off finishin him until after chrissi, bloody kids needing pressies and all that:)
Membergreedy53
Threads: 468
Mood: strung out
posted on December 11th, 2007 at 07:59 PM
bloody kids
[ Queries: 40 ] [ PHP: 19.5% - SQL: 80.5% ]
