| [ Total Views: 1710 | Total Replies: 8 | Thread Id: 67208 ] |
greedy53
Threads: 468
Mood: strung out
| posted on January 28th, 2008 at 04:28 PM |
t3 exchaust
is there any reason why a set of type i extractors wouldn't fit a 2.1 t3 as the basic block are the same
Menangler
A.k.a.: Dave Becker
Threads: 309
| posted on January 28th, 2008 at 06:37 PM |
The flange studs are at a different angle to Type 1 on the WBX engine. that's one reason I know of, could be changed if you are keen.
The WBX exhaust is great, I doubt you would gain anything with a Type 1 exhaust.
Dave
FAHRVERGNUGEN;
greedy53
Threads: 468
Mood: strung out
| posted on January 28th, 2008 at 07:29 PM |
thanks dave i was just wondering as you do
kombi kountry
Mood: horizontally op
| posted on January 28th, 2008 at 09:08 PM |
anyone out there replaced their T3 cat and muffler with something aftermarket and how'd you find it?
i got my cat and muffler replaced after getting the vintage vw power-up kit to restore some of the low-end power.
the muffler bloke put a resonator on it as well as he said it was too throaty
Iwish4aSynchro
Threads: 102
Mood: Cheery
| posted on January 29th, 2008 at 08:43 PM |
I got all i need down stairs in the garage high flow cat/resonator plus cannon power pipe, but muffler bloke reckons would be a waste of time, be too
loud he reckons.
Now i dont know what to do.
http://smallcar.com/index.php?act=viewProd&productId=5
It is American but still cheaper than anything in OZ... Cmon Aussie sellers stop loosing business and deliver.
Keep the steering and the propulsion seperate . Still a Kombi...
It's all good, until it's bad, i suppose
vwjon
Threads: 101
Mood: oily n thirsty
| posted on January 30th, 2008 at 06:47 PM |
greedy, the flanges are 90* out on one side, you also need to put quite a sharp kink the same pipe, i can't remember why i just know you have to do
it. you can also fit j pipes instead of heat exchangers, again one of the flanges is 90* out, easy when you have a welder and an angle grinder.
kombi, i've also fitted "other" mufflers instead of the origional box, a little time and a steady hand with the welder (use your old flanges in
case you find a bargain!) some of the mufflers are a little large and heavy, just fit an extra support bracket!! sweeeet!
don't worry about the cat too much so long as you keep the lambda probe in there!
hope that helps out.
if anyone has a t4 van price an exhaust system for the ute / pick up, i dunno why but its cheaper!! the tail pipe is about 8" too long!! wheres me
hack saw??
3 1959 cadillacs
1 musso
2 early notchbacks
2 split kombis
2 split panels
1 split ute
1 low light panel
1 ex-pmg bay
1 country buggy
1 beetle ute
1 14" syncro caravelle
1 16" syncro doka
1 golf cabrio
1 vw camper trailer
2 3meter bombs
1303Steve
| posted on January 30th, 2008 at 11:27 PM |
I ran a Type 1 system with J pipes on my old wasserboxer bug, pre turbo. Two opposing flanges need to be rotated 90 degrees, something like 1 and 4 or
3 and 2, cant remember off hand. On the 2.1 the water pipe coming out of the water pump runs straight into #4 pipe. I got around this by making a new
water pipe from stainless steel that hooped over the #4 pipe. I good merged system will wake one of these motors up.
On my old wasserboxer bug (pre turbo) I made 96 @ the wheels with a 2.1 with 8.00:1 comp (stock is 9.00:1), stock cam, 1.4:1 rockers, ported heads,
bug headers, slightly larger throttle body & Autronic SMC ecu.
1303Steve
| posted on January 31st, 2008 at 10:21 AM |
SS header make a header for vanagons. http://www.ss.headers.com
greedy53
Threads: 468
Mood: strung out
| posted on January 31st, 2008 at 06:24 PM |
thanks all my mate murray got a bloody nice muffler and twin pipe job done by wesy exhaust in sydney look him up inmembers rides under westy
again thanks all for ya help
