[ Total Views: 949 | Total Replies: 3 | Thread Id: 69474 ]
Author: Subject:  Removing spare tyre well from van?
MemberGeneral_Failure
A.k.a.: Tristan
Use your head, don't abuse it!
Mood: Not too bad. Thanks for asking!
posted on May 30th, 2008 at 12:37 PM
G'day.
It occurred to me today that I could save myself a lot of grief by removing the spare tyre well from my van, and possibly fitting an inspection plate.
The mattress constantly disappears into it , even with something over teh top which invariably slips, and it prevents me from having a decent bash at a big dent in the rear quarter panel.
The well looks like it was plug or spot welded in place around the edge.
Can I just drill out the welds and pop the well out? Or is there more to it?
If I do this how on earth do I go about attaching a plate in place? I imagine it wouldn't be hard to cut a chunk of plate to size and drill holes in it to match the positions of the drilled out welds.
After I do that how on earth would I secure it? Something like captive nuts inside the engine bay would be nice, but I don't know how to go about it.
I'll just glue a ring of rubber in place to make it vapour tight. That should be ample.
If at first you don't succeed. Build, build again.
Vehicle: 1975 Special order delivery walkthrough panel based LCA pop-top camper. Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002.
Memberkoolkarmakombi
enkarmarising
Threads: 158
Mood: do you see the bats?
posted on May 30th, 2008 at 12:42 PM
How about rivets and a plate to go over the top? Could hinge it to make it a hidey hole.....
If you drill it out and removw it weld a plate over the hole.
A.k.a.: Tristan
posted on May 30th, 2008 at 05:22 PM
Already drilled most of it out. That is the spot welds that haven't popped already or were dodgy in the first place.
Given that it was never really sealed in the first place, even a plate with a stack of nuts and bolts and RTV would be a better seal. Plus I can repair the gigantic gouge and dent in the side of the van, and it will come very handy if/when I do an engine conversion, because I would put a radiator there,
MembermnsKmobi
Threads: 27
posted on June 3rd, 2008 at 12:31 PM
It will also make it very easy to replace the rubber hose on the petrol tank breather system that allegedly lurks behind the wheel well and quietly rots out.
[ Queries: 40 ] [ PHP: 12.0% - SQL: 88.0% ]
