| [ Total Views: 510 | Total Replies: 1 | Thread Id: 6952 ] |
lugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
| posted on May 29th, 2003 at 08:26 PM |
40 IDFs (vents)
OK, they come as std in 28 and you can get 30s and 32s,can you go bigger from machining to 34 that is the question,Mick. |
Bizarre
| posted on May 29th, 2003 at 09:00 PM |
Definitely
Richard at V Force has put 34's in IDF 36's
I have stock 32's in my 36's at the moment
I am sure you can buy standard 34's for 40's and you could make some 36's that would work
lugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
| posted on May 29th, 2003 at 09:18 PM |
Thanks Barry blue74l or is it now red74l,yeah i just found some at CB perf.34 vents and you say 36 can be made to fit mmmm
interesting,thanks,Mick.:thumb |
70AutoStik
Threads: 18
| posted on May 30th, 2003 at 12:01 AM |
If you need 36mm venturis in your IDFs you probably need bigger carbs. Remember that such a venturi/throttle ratio will be utterly unstreetable, and
you don't need part-throttle response on the track.
Bizarre
| posted on May 30th, 2003 at 07:45 AM |
posted by lugnuts
or is it now red74l,,Mick.:thumb
nah still Blue.... as in red head = blue :P
