| [ Total Views: 943 | Total Replies: 4 | Thread Id: 69863 ] |
type3george
Threads: 1
| posted on June 17th, 2008 at 01:37 PM |
pre 69 bumpers
hi all new to this forum.
wanted know if anybody has or can you retro fit front and rear bumpers from a early type 3 fastback to a new type 3 fastback. |
Rocket
Threads: 12
Mood: Old
| posted on June 17th, 2008 at 03:03 PM |
Not Easily
posted by type3george
You can anything if you try but they do not interchange so would take a bit of work.
type3george
Threads: 1
| posted on June 17th, 2008 at 06:07 PM |
are the brackets in the same spot as the new version,
also can you get repro's for the type 3 |
vw54
| posted on June 17th, 2008 at 06:54 PM |
i suggest that you trial fit it up and use a measuring tape as well
VW-VARIANT-L
Threads: 1
| posted on June 18th, 2008 at 08:29 AM |
It can be done but you will need to fabricate/ modify the brackets. The pre-70 use 2 bolt mounting brackets at front, whereas 70-74 have larger 3 bolt
brackets.
