| [ Total Views: 700 | Total Replies: 11 | Thread Id: 7022 ] |
Starbug
rustbag
Threads: 148
| posted on June 1st, 2003 at 02:46 PM |
can anyone tell me (while my hands are dirty hehehe)
anyone know how many shims are supposed to sit on the fan in a beetle? i know there is probably a small difference between individual cars but how
many on the underside and how many under the nut/washer?
not too sure how these should go as the last fan f'ed up because of not enough shims!
any help would be greeeeeeat!  |
Starbug
rustbag
Threads: 148
| posted on June 1st, 2003 at 03:08 PM |
actually... not too big a need to know now, as the new fan is too big for the fan housing ive got! annoyance! so now ive got 2 questions
1) is a superbug fan housing bigger than than non-superbug fan housing and therefore can my bigger fan fit in it without scratching etc (the fan is
not bigger by diameter, just bigger by depth)
2) how many shims inside and out blah blah blah!
any help would be much appreciated!
[Edited on 1-6-2003 by Starbuggy] |
jenz58
Postal Menace
Threads: 230
Mood: Cruisy
| posted on June 1st, 2003 at 05:57 PM |
Wish I could. From the manuals I study it depends on the tension of the belt as to whether you add or remove shims.
I can't even get the nut off to remove the belt and pulleys to put a generator on I've cleaned up
I do the scew driver in the slot bit and all, but can't budge it:jesus
Quickbug
Threads: 16
Mood: Plucked...
| posted on June 1st, 2003 at 06:09 PM |
Jenz is right - just fit them on until the belt is the right tension, tight but so you can move it a little when grasping both sides of the belt in
between your thumb on one side and your fingers on the other (if that makes sense!?)
Its a bit of a trial and error. I have to change my pulley shortley!
Jenz - tried a liberal dose of WD40??
:bounce
jenz58
Postal Menace
Threads: 230
Mood: Cruisy
| posted on June 1st, 2003 at 06:36 PM |
Oops, forgot about that stuff, I have a can:thumb
Too dark and wet out there now
70AutoStik
Threads: 18
| posted on June 2nd, 2003 at 12:21 AM |
Yes, the doghouse fan will not fit in the early style fanhousings. The shims are used to set the fan-to-housing clearance. Put as many as it takes on
the generator side of the fan to prevent rubbing.
Quickbug
Threads: 16
Mood: Plucked...
| posted on June 2nd, 2003 at 08:43 PM |
Well i changed mine today since it blew up on the way to work.
I put 4 or 5 in the middle, between the two peices of the pulleys.
70AutoStik
Threads: 18
| posted on June 2nd, 2003 at 10:16 PM |
It blew up! How high you revving your engine?
BTW, It's a public Holiday here in West OZ, Foundation Day, you should live here - wouldn't have the problem.
Quickbug
Threads: 16
Mood: Plucked...
| posted on June 3rd, 2003 at 09:47 AM |
Yeah well i got all week off now!
SO NER!!
Oh but i am sick so that kinda ruins it...
How high?
Dunno - i havent put my tacho back in.
About 5-5.5k prolly. Maybe more.
Its the second pulley that has exploded on me... but they last about 6 months or so. They seem to be a big weak point...
edit--> its been dying for a bit - rattling and so on. Thought it might have held in for the rest of the week tho... rude bastard of a pulley...
I have been taking it easy - the one time i ask for some acceleration and it gives up the ghost...
[Edited on 2-6-2003 by Quickbug]
Starbug
rustbag
Threads: 148
| posted on June 3rd, 2003 at 04:43 PM |
Thanks ppls figured out the right amount... but had to buy a smaller fan
2nd hand for now... holidays soon so im going the upgrade (to the shinier chrom-ier doghouse and friends....)
the last fan i had on there got eaten through by the washer... not happy jan!:cussing |
jenz58
Postal Menace
Threads: 230
Mood: Cruisy
| posted on June 3rd, 2003 at 09:35 PM |
My belt was too tight and was the probable cause of the bearings going in the generator as it was fine until I'd been driving then it started
making terrible noises after a while. There were way too few shims and no give in the belt:jesus
Also learnt that shims are used to give required clearance for the fan so it doesn't hit or scrape anything as mentioned here.
Hmmm, it's all a learning but the hard way:o
Generator I've cleaned up is not charging but at least no horrible noises so bearings OK. Pity it doesn't work, have it looking so sweet
externally
Damn can't win
Can you buy new 6 volt gennies and regulators?
Quickbug
Threads: 16
Mood: Plucked...
| posted on June 4th, 2003 at 05:29 PM |
I think you can only get reco'd now Jenz.
Try giving Bosch a call though, as i got a new 12v generator only a couple years ago...
amazer
kombi pilot
Threads: 308
Mood: Peachy!
| posted on June 4th, 2003 at 06:23 PM |
before you go buying a new genny jenny hahahahahahaha haaaaa huh uh oh. OK. before you get another generator make sure its not something simple like
worn brushes.
jenz58
Postal Menace
Threads: 230
Mood: Cruisy
| posted on June 4th, 2003 at 06:41 PM |
Grey 57 is checking it out for me. Oops no he is putting bearings from a 6volt he has into the one we took out which was at least charging, but
suggested I find out if new ones are available. Still have the non-charging one on her.
He tried polarizing the gennie as well with no luck
Hmmm, the trials and tribulations of keeping Bel 6volt, 36hp
Looked online and all the results of my search were on 6volt-12volt conversions, so encouraging
*jen ponders her gennie problems*hehehehe
Grey 57
A.k.a.: Dean
Old Grey Cruiser
Threads: 355
Mood: (OoVoO) (OVO).
| posted on June 4th, 2003 at 10:46 PM |
Jen the fan end bearing was completely fried. Changed it over for a good one so it should be good to go.
One thing for anyone, this 6V gennie has 3 wires coming out of it not the usual 2. I know that the heavy one from the brush holder goes on one
terminal on the regulator and one goes on the other terminal. But what about the 3rd wire??
Any clues.
