[ Total Views: 928 | Total Replies: 4 | Thread Id: 70260 ]
Author: Subject:  Type 3 brake lines
MemberUnity-28
TOO LOW? NEVER
Threads: 146
Mood: Tucked In nicely!
posted on July 6th, 2008 at 05:57 PM
Type 3 brake lines
Hi all, does anyone know where I can get new metal Brake lines for the front of a type 3 for disc brake? If they are not available new, has anyone got any that they would part with? I would also need a Brake fluid reservoir as well....
Thanks Nectar.
MemberVWCOOL
Threads: 235
Mood: happy to help
posted on July 6th, 2008 at 06:20 PM
Any good brake shop/mechanics should be able to make them up if you provide a sample or an accurate measurement
Pay your debts, CxxT
MemberUnity-28
TOO LOW? NEVER
Threads: 146
posted on July 6th, 2008 at 06:47 PM
I have neither.....Im going from Drums to discs....
Super Administratorbarls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
posted on July 6th, 2008 at 06:49 PM
i bent a piece of wire up to the shape and length when i installed the brake boaster in the bug that was all they needed
the chaos project - click me
MemberStanley
Threads: 270
posted on July 6th, 2008 at 07:02 PM
I just finished making new brake lines for my drag car. Work out how long they have to be then go to your local barake shop and get them to flare the ends with a double flare. Then all you need to do is bend it to shape. It's easy as the brake line is pretty soft. As long as you bend them around something like a socket or a paint can (as long as the bend radius isn't to tight) it's a piece of cake.
[ Queries: 40 ] [ PHP: 12.8% - SQL: 87.2% ]
