| [ Total Views: 10485 | Total Replies: 101 | Thread Id: 70372 ] |
| Pages: 1 2 3 4 |
3amigos
Threads: 8
Mood: watched
| posted on July 31st, 2012 at 10:34 PM |
posted by LIFE IN THE LOW LANE
Got some new rims off C240 Merc sedan with tyres and fitted them up as well. 16x7 with offset of 43 fit real nice!! Just need some lower profile tyres
for the front to get guard clearance.
Looks good,has your kombi been lowered?
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
| posted on August 1st, 2012 at 12:58 PM |
Yup mine has been lowered since 1994. Long before the days of Buying bits and pieces to lower kombis even existed!! Been that long I cannot even
remember how many splines I went on te rear lol
| posted on April 23rd, 2013 at 03:25 PM |
New engine for the bus has finally arrived from the USA.
Fat Performance 2961cc
Scat 86mm stroker
JE 104.7mm pistons with spiral locks
Cast barrels
Cunningham 5.5' rods chev journals
Webcam 86c
1700 kombi rockers with 911 elephant foot adjusters
Manton chrome moly pushrods
Alloy pushrods tubes for stroker.
914 Porsche heads
48mm inlet
38mm exhaust
Case is clearanced for stroker and rods. 5th head stud mod and gusseted and braced on top of case at bell housing.
Larger main case bolts
Chrome moly head studs
Kennedy stage 2 clutch and pressure plate
Kennedy stage 2 flywheel lightened.
Flywheel runs aftermarket bolts and dowelled
CB manifolds for webers
48IDF webers
Custom made air cleaner boxes.
K & N tall air cleaners
Fat Performance throttle linkage
Fat Performance fan shroud with Porsche fan
80amp alternator
Autocraft dry sump pump
Petersen dry sump tank
Allydyne remote oil cooler with thermo fan
Buggy style exhaust with super trapp
Compufire CDI ignition
Will post some pics of the goodies now I've got it all pulled apart!!
tar76
Threads: 95
| posted on April 23rd, 2013 at 04:41 PM |
"Obey your Dreams"!
62 Std beetle.
65 11 wnd Split "The Cross".
6? coming very soon!!!!
DakDak67
Threads: 15
| posted on April 23rd, 2013 at 08:58 PM |
Oh Feerk yeh!!
| posted on May 2nd, 2013 at 09:10 PM |
OK so here's some pics of the new heart for my bus. Fanhousing will be changed as will exhaust and dry sump set up to get to fit into the back of my
bus!!
Remote oil cooler with thermo fan and built in thermostat
48 IDF webers with huge aircleaners!!
Scat 86mm Stroker with chev journals and cunningham rods
Kennedy stage 2 flywheel.H/D aftermarket bolts and dowelled as well. nice and light!!
Case reinforced at bell housing and 5th head stud added to hold heads on. Bigger heads studs and lots of case clearancing for crank and rods
Max loves the webcam 86c and straight cut cam gears LOL
will post some more pics once I start getting into cleaning everything up to reassemble.
matberry
| posted on May 2nd, 2013 at 10:14 PM |
Looks familiar..... Should be a tough bus with that in the back.
| posted on May 3rd, 2013 at 07:39 AM |
Got to do something to keep up the cousins Matt!!
| posted on May 5th, 2013 at 11:07 PM |
Picked up change over tinware at goldy show today. From early bays with type 1's but have the type 4 cooling seal in the engine bay. Got all the
tinware I needed for $40 and picked up a late kombi steering wheel for a real good price as well!! First time I've had a Horn that works for nearly
15 years!! Just have to keep reminding myself not to tap on it to the music!! Lol
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
| posted on May 6th, 2013 at 01:36 PM |
So we'll see this racing at Warwick?
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
reub
VWRX is gone...
| posted on May 6th, 2013 at 02:39 PM |
still remember seeing that engine on ebay a while back...
3Lt should give plenty or torque
Reub
| posted on May 6th, 2013 at 08:33 PM |
Was for sale on Samba Reuben. 3 odd months of negotiating before it wash finally a done deal.
Graham Warwick may be a possibility but between now and then I have to finish some minor renos to sell my house and find somewhere else to live then
obviously move. Troys car would be closer to being at Warwick than mine and that will keep me busy at the track!!.
On a side note tracked down a vac advance type 4 dizzy this arvo in good condition!! Thanks tar!!
| Pages: 1 2 3 4 |
