[ Total Views: 1393 | Total Replies: 8 | Thread Id: 70401 ]
Author: Subject:  Kombi box ?
Memberliam66
Threads: 90
posted on July 13th, 2008 at 01:48 PM
Kombi box ?
I'm toying with the idea of going subaru in my buggy.
Will a kombi box stand up to a wrx 2.0 turbo motor? I dont want to do burnouts or thrash it, but I'm after something that I don't have to completly baby.
Does the kombi box fit in the beetle without much surgery?
MemberBrad
Threads: 332
Mood: Manx Buggy Building
posted on July 13th, 2008 at 02:04 PM
A kombi box will handle the bower if you don;t drive stupid. Kind of like putting a Lexus V8 in a Suzi.....
the 091 Box is the best fit and strength out of what you have as easy options and it fits in without to many issues. Does your buggy have a lift kit ? If not with the body you have you may have to clearance the glass a little at the back as the kombi box sits higher. Custom Vee Dub ( http://www.customveedub.com.au ) do a kombi transmission kit which ie very good and has a front and rear strap included. I have one of their kits in my Buggy which is running an EJ 22 and it works sweet. I also had one in my Baja which was running an EJ20T and it was fine. I blew a few box's though with the 33" rear tyres and weight which was closser to a tonne.
Wes is running a kombi box with his V6 and no issues to date, it all comes back to how you drive.
Brad
Meyers Manx Australia
MemberTHUDKNUCKLE
A.k.a.: James Stoodley
Threads: 25
Mood: Crazy
posted on July 18th, 2008 at 05:32 PM
definatley comes down to how you drive lol , after getting on my car ( rotor baja) a fair bit in the past few weeks my 091 is starting to make a lil bit of noise . lol oh well its what happens when you have i guess lol. but prior to this doin nothing crazy but not pussy footing everywhere the 091 held up perfectly.
Love is a Rotary baja bug
Just be carefull :ninja:,, something dangerous is lurkin in My garage ready to burst out in a fit of Big Hp, high boost baja Rage .
http://groups.msn.com/GottaVW
posted on July 18th, 2008 at 05:53 PM
these mounts are great and mean that you can use the stock shifter shaft rather than running a shift rod along the top of the tunnel
http://www.pitstopautoinc.com/mm5/merchant.mvc?Screen=PROD&Store_Code=PAI...
Memberliam66
Threads: 90
posted on July 19th, 2008 at 10:31 AM
So the Custom vee dub kombi box kit has the shifter running outside the tunnel? That doesn't sound good.
The pitstop mount lookls like it has an adapter for the shifter on the front?
This is all I need?
Pitstop had some other goodies that looked pretty nifty
This looks like a better clutch setup;
Memberratbug
A.k.a.: Andrew Todd
aka toddy101
Threads: 30
posted on July 19th, 2008 at 12:16 PM
Isn't the other bit to the kit just the front gearbox mount? Not sure how it will be any different to mounts provided locally?
The kombi box gear selector is a couple of inches higher than the beetle one, so with mine, i just weld two selector to rod coupling's together. It sticks out of the rear inspection cover, but you can just make a new cover to go over the top. This is BlueV2's setup..
http://www.pa.com.au/tmp/v2/gboxdone.jpg
http://www.pa.com.au/tmp/v2/coupling.jpg
Manxter with FA20turbo
Click here for wiring looms
Memberratbug
A.k.a.: Andrew Todd
aka toddy101
Threads: 30
posted on July 19th, 2008 at 12:18 PM
Also, the CNC stuff you can get locally from a few places.. Except I havn't seen that slave cylinder saver... Wouldn't mind one actually.
Membertype3dub
Threads: 4
posted on July 19th, 2008 at 03:09 PM
Hi guys I'm new here. Will this conversion fit the kombi box to the type three aswell ?
posted on July 20th, 2008 at 08:52 PM
In some ways a late type 3 is easier as the tranny hangs from the body and doesn't have to clear the horns like in a beetle. However, you could probable do with extra bracing.
Like this sort of thing would be good
http://forums.aussieveedubbers.com/viewtopic.php?tid=64482&page=1#pid607647
Everything else is a really a custom bracket setup I'm afraid. You'll have to make it up yourself. Not very hard, but there you go. Nothing straight off the shelf. Sorry.
[ Queries: 40 ] [ PHP: 11.9% - SQL: 88.1% ]
