[ Total Views: 1689 | Total Replies: 16 | Thread Id: 71688 ]
Author: Subject:  baja kit for super???
Memberbaja burley
posted on September 12th, 2008 at 09:11 PM
do they make baja kits for superbugs??? if so how much and where do i get one??
There are three types of people in this world - people who can count and people who can't....
MemberRISKYBUG
Threads: 9
Mood: RISKY IS 1337
posted on September 13th, 2008 at 06:38 PM
i dont think there are any
the rear end you can cut up but the front is bad news for baja
MemberRISKYBUG
Threads: 9
Mood: RISKY IS 1337
posted on September 17th, 2008 at 06:40 PM
anyone else??
if it's not going on road then cut up the back and cut the front guards so you can put big rims on
anyone know of a way to make the front end stronger on a sbug??...with out going to a beam!!
Memberang3lsholocaust
Threads: 58
Mood: so in love..
posted on September 18th, 2008 at 03:51 AM
Cut the bulk head off and weld a ball joint or link pin bulk head on.
Like this thing
http://www.manxgallery.org/gallery/albums/album167/136585_G.sized.jpg
MemberRISKYBUG
Threads: 9
Mood: RISKY IS 1337
posted on September 18th, 2008 at 01:35 PM
and is it regod in au??
never seen it done before!
Membervwsteve
A.k.a.: steve
karmann crazy
Threads: 200
Mood: Busy!
posted on September 18th, 2008 at 03:11 PM
looks like the us to me
1 1963 356b porsche coupe
2 1960 karmann ghia cab
1 1965 karmann ghia cab
1 1966 karmann cab
1 1961 split ute
1 1967 split p/van
1 1952 standard bug
1 1963 ragtop
1 1960 ragtop
2 1954 ovals
1 1956 oval baja project
1 1957 oval flying flea
MemberVWCOOL
Threads: 235
Mood: happy to help
posted on September 18th, 2008 at 03:29 PM
Not many Super-based Bajas around, but using a non-strut chassis under a Super body blends the 'best' bits from factory VW components for off-road use
HOWEVER with a nice, soft, long-travel spring (a la Nissan Pathfinder) I reckon a coil-springer would be pretty good too!
Pay your debts, CxxT
posted on September 18th, 2008 at 06:50 PM
that bugs LHD so yeah its probably a yank car
theres a super baja bug in volkswagen australia #1 that appears to cop a severe thrashing off road
but easiest way around it like jace said just convert to beam front end
enough ppl around are doing now
MemberRISKYBUG
Threads: 9
Mood: RISKY IS 1337
posted on September 18th, 2008 at 08:41 PM
hi joel
that looks like a nice convertion
where is it from?
Memberbaja burley
posted on September 19th, 2008 at 01:32 PM
what mods do you have to make to mount the beam or does it just bolt straight on
posted on September 19th, 2008 at 03:08 PM
that ones actually a super body on a standard floorpan but the end result is the same as fitting a beam bulk head and bolting up a BJ beam
theres a bit of work in the change over
gotta take the body off remove the strut bulkhead and weld in a beam one
it would need to be done with a jig i imagine cos u wouldnt wanna be out at all otherwise u would end up with a bug that crabs down the road
ill have a dig around over the weekend see if i can find volkswagen australia #1 and ill scan the artical cos i havent seen it for probably 10 years so cant remember how he built it
Memberbaja burley
posted on September 19th, 2008 at 09:48 PM
Threads: 58
Mood: so in love..
posted on September 20th, 2008 at 12:37 AM
Yeah the yellow one above is a yank car.
Just pointing out how you could do it if you really wanted to.
Would be far easier doing it with a regular beam beetle then a super bug.
MemberVWCOOL
Threads: 235
Mood: happy to help
posted on September 20th, 2008 at 09:06 AM
... don't forget the wheelbase difference...
posted on September 20th, 2008 at 08:30 PM
is there a difference Glenn?
i just know of a few superbug floor pans fitted with beam bulk heads and standard bodies or left with a super body as per the red vert i posted above
its a 71 super body on a 69 floor pan
posted on September 20th, 2008 at 08:36 PM
Put a beam in and a one piece bonnet and guards if it has the flatter screen
Memberbaja burley
posted on September 22nd, 2008 at 05:25 PM
what can i do to the strut system to strengthen them without doing any major chopping and replacing??
[ Queries: 40 ] [ PHP: 17.5% - SQL: 82.5% ]
