| [ Total Views: 1202 | Total Replies: 13 | Thread Id: 71823 ] |
Kafer Lover
Threads: 71
Mood: Low
posted on September 19th, 2008 at 10:07 PM |
[FS - VIC] 54 Rat oval project - will separate from engine
Seller: Tim
Phone: 0425767988
*** I will consider selling the car separate, and keeping the engine for my '68, so if anyone is interested in the body and pan together (don't want
to separate) I'd take $3800 for body and pan.****
Up for sale is my 54 oval project. The body has had the structural rust repaired, including heater channels replaced. See photos.
The rear clip is removable, undo a couple of bolts and its off to get the engine in and out easy.
Rear body mounts have been moved to fit onto a late pan.
Body has surface colour rust and a few dents in the roof over the driver, but this is part of the charm and beauty of this car.
Included are a brand new visor to replace the broken one,wiper arms, horn grilles and headlights with early glass. Also included painted original
petrol tank.
The pan is '76 ball joint manual. Lowered front beam. Front and rear sway-away sway bars. Includes '76 single side plate gear box with solid mount.
New urethane shift coupler installed.
Pan has been Por-15 silver top and bottom, with rear running gear in Por-15 schwarz.
Empi shifter included. '76 bucket seats included.
Also included is a 2275 engine with all the good bits, specs are:
2275cc Type 1
82mm CB Performance Chromoly crank, nitraded, balanced
5.5 inch CB Perfomance Chromoly race rods,
Steel Billet cam, ground to K-8 specs with heat treated lifters
94mm pistons fitted with Total Seal rings
Stan pobjoy Anti surge sump
Berg Chromoly pushrods
040 heads fitted with 40 x 35.5 valves, fitted with Berg dual springs
Berg collets, retainers & lashcaps
9.5:1 compression
Berg 1.4 ratio rockers
Tall CB manifolds, match ported with twin 48mm Webbers
which are brand new
2 way oil pump setup for external oil cooler including RX7 oil cooler and a couple of kombi fans to provide added luft over the cooler.
S & S 1 5/8 inch merged header with merged 2.5 inch system & muffler
009 distributor fitted with compu-fire ingnition module
Comes complete with all tinware, flywheel, clutch etc ready to install
I would rather keep the car together with the engine as a single project, hence listing them together.
If someone is keen on the body and pan, without the engine I could do this, although I'd rather see it go together.
Price for all of the above: $10800.
more photos to follow...
I also have some other goodies that I have been collecting separately for this project including semphores, tail lights (55, not 54), popout windows,
T bar bumpers, steering wheel and trip meter speedo, which I will be listing separately shortly. However if someone buys the project, I will give them
first dibs on the other booty.
Cheers, Tim.
| Error |
| Error |
| Error |
Kafer Lover
Threads: 71
Mood: Low
| posted on September 19th, 2008 at 10:08 PM |
photos:
| Error |
| Error |
| Error |
Kafer Lover
Threads: 71
Mood: Low
| posted on September 19th, 2008 at 10:10 PM |
photos of the heater channels and inside...
| Error |
| Error |
| Error |
Kafer Lover
Threads: 71
Mood: Low
| posted on September 19th, 2008 at 10:12 PM |
underside of pan and shifter
| Error |
| Error |
| Error |
Kafer Lover
Threads: 71
Mood: Low
| posted on September 19th, 2008 at 10:14 PM |
engine and accessories:
| Error |
| Error |
| Error |
Kafer Lover
Threads: 71
Mood: Low
| posted on September 19th, 2008 at 10:18 PM |
few more shots.....
| Error |
| Error |
| Error |
h
| posted on September 20th, 2008 at 11:16 AM |
pm to you..
matberry
| posted on September 20th, 2008 at 01:28 PM |
Those are Whiteline swaybars
beerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
| posted on September 20th, 2008 at 05:34 PM |
Tim
Have not seen you for ages mate BUT what are you doing
Will have to catch up
Come for a coffee at reVOLKS 18th Barking Dog 9.30am then cruise to Lorne
Cheers Doc
reVOLKS at Fyansford Geelong
beerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
| posted on September 20th, 2008 at 05:38 PM |
Still got mylovw thats good
Cheers Doc
Kafer Lover
Threads: 71
Mood: Low
| posted on September 20th, 2008 at 08:12 PM |
yes, whiteline bars...had a bit of a brain fade.
Doc, would be good to catch up..see the Rhino is looking great.
BenettonVW
AVD Forum Founder
Threads: 185
| posted on September 22nd, 2008 at 07:40 PM |
Tim.... WTF?!?
Good luck with the sale. Bump!
Kafer Lover
Threads: 71
Mood: Low
| posted on September 22nd, 2008 at 10:16 PM |
Thanks Jim,
I know...I know...
Kafer Lover
Threads: 71
Mood: Low
| posted on September 24th, 2008 at 09:04 PM |
bump
