| [ Total Views: 717 | Total Replies: 1 | Thread Id: 7183 ] |
Secoh
Threads: 97
Mood: Rarin' to
| posted on June 5th, 2003 at 05:46 PM |
Bellhousing questions
Is it only the kombi/caravelle bellhousings that are removable? if so, is the bolt pattern where it bolts to the box the same for all models?
If it aint broke,
Make it go faster!!
Old Dubber
Threads: 25
Mood: great!
| posted on June 5th, 2003 at 06:01 PM |
It's the same bolt pattern for the Kombi 1600,1700, 1800 and 2ltr, don't know about the Caravelle
Secoh
Threads: 97
Mood: Rarin' to
| posted on June 5th, 2003 at 09:54 PM |
So can I bolt a type 1 motor to a kombi box ok?
the beetle box never had a removable bell housing? |
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on June 5th, 2003 at 10:27 PM |
the beetle never had a removable bellhousing.
To bolt a type 1 into a type 2 trans, you will need to put a type 1 input shaft in it (or cut a little off the type 2 one). This applies to gearboxes
made for the type 4 engine.
Secoh
Threads: 97
Mood: Rarin' to
| posted on June 6th, 2003 at 08:42 AM |
Thanks Wes....the reason for the questions, is I have a renault 5sp box now, and found someone that makes adaptor plates to fit a vw bellhousing to
the renault box.
however he didnt say what type of vw bellhousing. I'm hoping to use a caravelle one so I can use a hydraulic clutch.
If it aint broke,
Make it go faster!!
