[ Total Views: 654 | Total Replies: 5 | Thread Id: 7255 ]
Author: Subject: Missing engine
Memberpaulr
Threads: 103
posted on June 7th, 2003 at 09:06 AM
Missing engine
Engine Missing
Hello All this is driving me mad . I lent my car to the wife (1st mistake), she filled it with Optimax and drove it or a week – comes back with a miss – it is fine or not noticeable under load but at idle or cruising in 4th it is a constant –I have checked most things – plugs, points, tappet gap , wires to carbs, timing etc but cannot find it.
Any ideas ? IT is a dual port standard twin carb type 3
Paul
Dazed and Confused
and riding a pushi
Membersikdub
Mood: svweet
posted on June 7th, 2003 at 10:11 AM
Hey Paul,
Try pulling out your idle jets and making sure they're not blocked. had this problem with the square and it was a bitch till we worked it out.
Steven
Membergeodon
Threads: 63
Mood: stumbling
posted on June 7th, 2003 at 10:13 AM
Pin it down 1st
At idle, disconnect each HT lead in turn. If you're a wooss like me & are afraid of a HT shock use a work glove but connect it (the glove) to earth via a lead & a couple of croc clips- trust me- it really works!
You'll find that disconnecting a "good" cylinder will drastically affect the idle-ie make it go real slow. Disconnecting the bad one will logically have no effect on the idle. Then go thru the electrical side with a fine tooth comb.
Start at the HT terminal on the dist cap- look for arcing signs or cracks internally. Look where the HT plugs into the cap- is it clean or sooty. Check the HT lead to the cylinder by replacing it even temporarily. Is the plug connector ok? Maybe trim a bit of wire off the plug end & then screw it back in. If you have new plugs, then that should be the end of it. If it's still missing, it's bad news & time for a compression test.
Good luck!!
Member70AutoStik
Threads: 18
posted on June 8th, 2003 at 11:59 PM
Your engine is missing? Maybe she sold it! :D
Seriously, though; I'd pull the plugs and see if they're fouled. That's about the only thing that could be related to the fuel.
Memberpaulr
Threads: 103
posted on June 9th, 2003 at 10:18 AM
Thanks for the help guys - have done some of that stuff but will look into the rest.
Funny how some engines never play up and others just like to test you
Cheers Paul
Dazed and Confused
and riding a pushi
Member70AutoStik
Threads: 18
posted on June 10th, 2003 at 11:29 PM
Yeah.
All cars are female - but some seem to think they're married to you. :D
Member555bug
WRX Bug Boy
Threads: 79
Theme: UltimaBB Vintage
Mood: turbo charged
posted on June 10th, 2003 at 11:45 PM
hey when you locate the cylinder thats missing, pull the hi tension lead from the top of the dizzy. Start the engine in the dark somewhere and look to see if there is a spark arcking anywhere...perhaps on the lead from the coil to the doghouse? i'll bet thats you trouble.
MemberJOE751
Threads: 15
Mood: Apathetic
posted on June 11th, 2003 at 12:17 PM
Id go the idel jet
Optimax has stuff in it to help "clean" so i hear. I have had trouble with it disolving shit and placing it in my idle jet..very uncomfortable....take it out and spray and blow it out....
easy starting point anyway
Memberpaulr
Threads: 103
posted on June 11th, 2003 at 06:43 PM
Thanks people
I have decided to wait untill my new webers are on it that will at least eliminate carb issues.
Cheers Paul
Funny though it was purring before the Optimax
Dazed and Confused
and riding a pushi
