| [ Total Views: 6926 | Total Replies: 167 | Thread Id: 7309 ] |
| Pages: 1 .. 4 5 6 |
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on February 22nd, 2004 at 01:29 PM |
Reindexed the rear suspension one inner spline which equates to around 9 degrees lowering or about 6cm roughly. The suspension should settle down a
little more with a bit more weight. Rears will easily clear guards which is great, had to grind off some of bumpstop to ensure I didn't rub on
that.
Fronts will be tighter and will most likely roll guard lips but shouldn't have to narrow beam as I first initially thought.
Pic below shows dual dells (40mm) mocked up. Still figuring out access panels/holes to make tuning easier. Also have to finish removable rear apron
before I pull the body off again.
alan
Bumpstopbus
Threads: 4
Mood: oooohhhhhhyeahh
| posted on February 22nd, 2004 at 04:33 PM |
Hay Alan she is getin close mate,that would have to be the worst thing about doin a custom job getin every thing to fit and work just right.Is it
going to be ready for valla?:thumb
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on February 22nd, 2004 at 09:22 PM |
I will be pushing hard to get it done for valla kurt. I would say without much doubt it will be ready but I don't want to jinx myself!!
Anthiron
A.k.a.: Nicko McKay
The Baja Rejuvenation Begins
Threads: 310
posted on February 22nd, 2004 at 09:41 PM |
looking very very awesome keep up the good work:thumb
1974 Chevrolet Luv
1970 MK2 Ford Cortina GT
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on February 25th, 2004 at 09:09 PM |
Had a bit more of a fiddle with the removable rear apron tonight - the new replacement apron of course doesn't fit quite right since the pressing
is not the same on the top corners as the original. Wish I had a NOS one!! Brazilian stuff...hmmm...sometimes okay but others not so okay.
Anyway, nothing major, just more work to make it right. Second pic just shows the clearance under the engine block...didn't have a can to show
height...only had a grease tub!
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on March 1st, 2004 at 08:06 PM |
Another mockup of the engine "tin" wear. Figuring out now where I have to drill holes, make brackets, cut etc before any paint is laid down.
Shroud is just resting at the moment - not bolted in.
Bumpstopbus
Threads: 4
| posted on March 1st, 2004 at 08:22 PM |
Hay Alan lookin good mate,are you going to weld the exhaust slots up as well or are you goin to leave them.With a motor like that you should be puttin
a tuned exhaust system on it.
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on March 1st, 2004 at 08:30 PM |
Kurt I am going to leave them as I would like to have either a twin outlet (will get a custom exhaust) or single with a dummy in a nice size pipe.
Will get someone here in brissy to build it as supposedly exhaust is everything in typeIVs so don't want to screw that part up!!
There is a bloke who has a turbo metallic red typeIII who had his exhaust made up by someone here in Bris - will follow that lead up when it comes
time!
nbturbo
Threads: 89
Theme: UltimaBB Powder
| posted on March 2nd, 2004 at 12:33 PM |
It's probably buried somewhere in this post-is that a Sharpbuilt fan kit?Good looking finish on the fibreglass.Should be easy enough to get motor
out without a removable rear apron???
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on March 2nd, 2004 at 09:15 PM |
g'day nbturbo - yep it is a sharpbuilt kit. The finish on the fibre glass is very good - will need minimal prep before the primer/two pack is
laid down.
The removable rear apron will make life a lot easier as I am sure the engine will go in and out a few times whilst sorting out all the new project
bugs.
lil bug
Threads: 15
Mood: slightly nutty
| posted on March 5th, 2004 at 09:05 PM |
Nice ride, u've done a sweet job. Cant wait to see it all done.
Hey how r u securing your rear apron? Could u post a few more pictures showing what u've done with it?
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on March 6th, 2004 at 08:01 PM |
Thanks lil bug, I have only thus far modified the replacement aprong to fit but haven't quite decided on the way to fix it in place just yet -
will update as I go.
Here are another couple of boring pics of the engine. Got the breast plate in place after a bit of fine tuning (nothing major). Still tinkering with
the rear apron.
Third pic just shows the washers I used to determine the width of the spacers I will be getting made in the next couple of weeks (probably around
28-30mm). Spoke to the automotive engineer I am going through and he said that this method of spacing the wheels out is okay (I will be holding him to
his word!!). :P
nbturbo
Threads: 89
| posted on March 7th, 2004 at 07:32 AM |
Did you see the article on removable rear apron in a VW Trends near the end of last year?From memory it was one of their better how to articles.If you
didn't see it I will try and find it.
Bumpstopbus
Threads: 4
| posted on March 7th, 2004 at 06:22 PM |
Hay Alan who are you usein to get all the mods approved.
Does he come out to you or do you have to take it to him.
I am lookin for someone to approve my disc brakes when it comes time.
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on March 7th, 2004 at 09:17 PM |
Thanks nbturbo - I didn't see that article - that would be sweet if we could work out some way for me to see it (shhh...maybe scan, photocopy or
whatever??).
Kurt, I am going through a fellow called Richard Larson ( http://www.loadsafe.com ) -
he did all the mod inspections for Wes's baja V6 conversion. I have arranged to get stuff to him to inspect but thus far have mainly just had
phone contact and only one inspection of my brake bits way back when. He can be a little hard to get onto sometimes but is pretty good with giving
information that is required.
Alan
nbturbo
Threads: 89
| posted on March 8th, 2004 at 01:57 PM |
I found the article-August 2003.If you can't find it -email me and I will photocopy it and post it to you
lil bug
Threads: 15
| posted on March 12th, 2004 at 05:03 PM |
Thanks I'm still trying to work out if thats the way I will go.
No I dont have that issue, would u b able to email it to me... pleeease.
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on March 14th, 2004 at 09:26 PM |
Had a bit more of a fiddle with the engine cooling tin today. Had to cut the existing doghouse oil cooler tin off to make way for the wider fibreglass
extension piece to fit the typeIV cooler inside. Not a fun job, but not that bad.
Also made the holes for the oil lines in the shroud, trial fitted a dizzy for clearance (this is not the one I'll be using). Alternator clearance
on the stand may be an issue (not seating properly - the front lip is hitting rather than the actual body seating in the stand). Got the cooling tin
around the manifolds to fit (after having to clearance the manifolds)...all part of the fun....of course after I had them HPC'ed. This is why the
trial fit is important - I'd hate to do all this after everything is painted nice and shiny!
Alan
Brad
Threads: 332
Mood: Manx Buggy Building
| posted on March 15th, 2004 at 09:59 AM |
mmm
Wheel spacers.. I am guessing you are going to get complete spacers made, ie not 5 seperate spacers, rather one large plate.
Just remember it is the friction / contact between the two areas that gives the wheel its drive, not the studs.
Looking cool :>
:thumb
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on April 4th, 2004 at 07:45 PM |
Administrators?? I know there have been problems with the attachments and multiple attachments and these are being resolved (I think) - I don't know
how many posts have gone missing from this thread though and why all the other pics aren't loading? Any help is appreciated as I'd like to update
the progress but don't know where to start from when I don't know what is missing and what pics are where.
ta
Alan
Che Castro
ankle straps
Threads: 79
Mood: (( }:-{D]
| posted on April 8th, 2004 at 03:57 PM |
wow...
the last 2 pages of pics dont work????
Jon
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on December 17th, 2004 at 10:12 PM |
Wow just saw this old thread which has the last few pages of pics that didn't load - a bit of blast from the past....especially the bit about having
it ready for valla....yeah right!! Ah well, wishful thinking!
Just like it was supposed to be ready for dubs by the pub....last year!! It would have if I didn't keep changing my mind about certain aspects of the
project!! Looks like most stuff is finalised though so now for paint.
| Pages: 1 .. 4 5 6 |
