[ Total Views: 1286 | Total Replies: 8 | Thread Id: 73716 ]
Author: Subject:  6v to 12v conversion
Membermonster
Threads: 7
posted on December 30th, 2008 at 09:42 PM
Hi all,
I am a newbee here and I am wanting to buy a 1967 or earlier bug. Most of them are 6v and I wanted to get some idea of price for converting them to 12v and what are the pros and cons of doing so.
Any advice is appreciated,
Cheers,
Blair.
posted on December 31st, 2008 at 11:35 AM
depends if you want to change the flywheel as well you would have to pull the engine
you need a generator or alternator, starter, coil, wiper motor, reguator, light globes, battery, 12volt flywheel if yr changing it and possibly a clutch and pressure plate as the size will be different
Membermonster
Threads: 7
posted on December 31st, 2008 at 01:22 PM
so... safe to say that it will cost a bit... probably more than the car itself???
posted on December 31st, 2008 at 01:36 PM
Its a piece of string answer
If you are doing it yourself the MINIMUM would be battery, bulbs, generator, coil and ???
You could get out for say $200??
Drive in / out of a shop and get everything done - $1500 at least
posted on December 31st, 2008 at 05:53 PM
unless ur getting a bug thats been in storage for eons u probably wont encounter that many still 6 volt
most of them have been converted by now
6 volt batterys have been getting harder to get and big $$ for ages and replacement bulbs can be fun to track down not to mention gennys and regulators which tend to die after 40+ years
Memberpod
A.k.a.: paul mrvw061
Mood: could be better
posted on December 31st, 2008 at 07:30 PM
dont forget the genny or alt stand as well;)
check wbsite for location
All Welcome
http://www.flatfour.org/
Membermonster
Threads: 7
posted on January 1st, 2009 at 08:28 AM
I have come across several that are still 6v... whilst I would like to keep them original as possible, 6v is a pain in the butt. So I would like to do the conversion 100% properly and not cut any corners...
Memberizac
Threads: 39
Theme: UltimaBB Powder
posted on February 1st, 2009 at 11:48 AM
i have a 65 type 3 that is still 6v. i am thinking about converting it but it does seem like a lot of trouble as everything is working fine anyway. the only reason i want to convert is so i can run a 12v stereo...
the previous owner looked like they were running 2 batteries (using a 12v for the stereo system and 6v for everything else)...
is this alright to do???
are there any other options?
Memberdavog1970dubstar
Threads: 2
posted on October 13th, 2009 at 08:52 PM
dizzy condenser
i a newbie to aircooled so far and have had some trouble with the dizzy on my 1500 burning points, is there any difference between 6v/12v dizzy set up????
i currently running 12v but have dizzy off old 6v engine set up??
any suggestions?.
[ Queries: 40 ] [ PHP: 12.0% - SQL: 88.0% ]
