[ Total Views: 1098 | Total Replies: 4 | Thread Id: 75057 ] |
rob53
Threads: 62
posted on March 2nd, 2009 at 01:28 PM |
Whats the trick with painting panels and the holes for body trim?
Here is a trivial question I'd like to put out.
After I painted my bonnet (will be do it again later though )
the holes for the chrome trim and emblem had gotten smaller.
I ended up chipping the paint when putting the plugs in for the emblem.
What's the best way to avoid this next time? I used a drill bit by hand to lightly take off the paint in the holes, but I'm worried it may scratch
it too far and expose some metal.
Thats not rust, it's ah ... orange primer ... yep that's what it is ...
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on March 2nd, 2009 at 05:39 PM |
You could drill them back out just before the final colour is going on. This would eliminate the thickness of any puttys. Or drill them .2mm bigger
before you start to allow for .1mm paint per side of the hole.
Dilbert
Threads: 8
posted on March 2nd, 2009 at 08:28 PM |
if your worried about about a little metal showing and having some rust show up you could spray the area with something like wurth cavity protection
spray. put the trims on then wipe the area clean.
rob53
Threads: 62
posted on March 3rd, 2009 at 08:53 AM |
Drilling before the color coat sounds like the go.
Thanks fellas.
vw54
posted on March 3rd, 2009 at 09:40 AM |
yep jus trun through them B4 paint cleans out all the primer and overspray
