| [ Total Views: 1881 | Total Replies: 19 | Thread Id: 75168 ] |
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
posted on March 7th, 2009 at 01:31 PM |
My car's Phat, or should that be Fat
So I went to the dump today, and I asked how much my car weighed on the weighbridge. If I subtract my weight I get;
[size=24]1140kg!!![/size]
That's my car with about 1/4 of a tank of fuel. Pretty heavy huh? I guess it needs the V6 to move it around
ian.mezz
Threads: 280
| posted on March 7th, 2009 at 02:37 PM |
mY super bug ej20t full of fuel 941kgs ,plus me add another 88kgs and i dont have Air/Con yet.
pete wood
| posted on March 7th, 2009 at 05:03 PM |
posted by Baja Wes
Jeez, and I thought mine was heavy at 910kg. You might be 35hp up on me but you can keep it if you're dragging an extra 200kg or so.
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on March 7th, 2009 at 05:42 PM |
Well a stock 68 is about 840kg. So I have an extra 300kg from somewhere. I have;
* 2 inch body lift
* type 2 091 trans
* V6
* radiator and cooling system
* climate control air con with automated flaps and all sorts of things
* lots of bar work at the rear to make a support cradle for the engine
* very heavy wheels and tyres
* a tool kit under the front
* heavier jap seats
* very heavy sound system with subwoofer box, amp, etc
I guess it all adds up. Anyway, it adds up to the performance figures I measured ages ago. I had no air con, toolkit or subwoofer in it when it did
0-100kph in 6.3s on the G-tech. When I put my dyno curve into my ExcelDyno program I found I needed it to weigh 1150kg with driver to do that time. So
I guess I always suspected it was that weight.
silver
Dangerous when poked
Threads: 162
Mood: In 2 Minds
| posted on March 7th, 2009 at 06:03 PM |
I too went to the dump today,
my split screen container van is 1490kg empty (without me)
Keeping it real !
reub
VWRX is gone...
| posted on March 7th, 2009 at 06:57 PM |
From memory VWRX is 950kg - without me in it... and I thought that was heavy mate.
Reub
matberry
| posted on March 8th, 2009 at 05:43 PM |
posted by Jak Rizzo
I couldnt' see many 12 second vw powered bugs taking the kids to school each day.
Jak
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on March 8th, 2009 at 07:15 PM |
Yours is a lot faster than mine Jak. Mine would only be good for a mid 14 down the quarter. Baja's are heaps slower than L bugs though. At one stage
I owned an L bug with a very mild 1776 with twin kadrons. In my Baja I had a far more modified 1916 with twin 44IDF webers, high ratio rockers, bigger
cam, 044 heads etc and the L bug was just as quick as my Baja. Faster over 100kph.
Andy
Andy's Adventures
Threads: 181
Mood: Happy Man
| posted on March 8th, 2009 at 08:39 PM |
Don't worry Wes, my kombi weight's in just under 1.9T with me in it, so that's close to 600kg above stock.
That's with the water tank and extra fuel tank empty (they hold 45L each).
Add the family and supplies and we quickly reach the GVM. All that with stock motor, so an optomistic 70hp.
The best dump trip I have done pulling a Tandem trailer was over 3T on the way in.
pete wood
| posted on March 9th, 2009 at 07:40 AM |
posted by Jak Rizzo
It's not just the power Wes, as u know full well with your own conversion, it's the comfort factor, the quietness...
SORRY, CAN YOU REPEAT THAT PLS? I DIDN'T QUITE CATCH WHAT YOU SAID THE FIRST TIME!
quiet? yeah sure, maybe in your car. mine's loud as on the inside.
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on March 9th, 2009 at 09:44 AM |
If I don't get into mine, then it is quiet. Actually my gearbox is noisier than the engine on the highway, and it's in good condition. It certainly
is comfortable too. I didn't go for out-right speed, otherwise I would have went for the EJ20T because it's easier to get more power from it.
I have wondered whether I need a 12" subwoofer or not though, because it certainly is heavy. If I went to the drags I'd pull the extra stuff out,
but around town all the optional extras are nice to have.
pete wood
| posted on March 9th, 2009 at 01:36 PM |
yeah, my trans mounts are the thing that has caused all the extra noise of late. but I wouldn't swap a quieter car for the way the chassis works now.
now way. it's actually puts the power down instead of flexing all over the place.
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on March 9th, 2009 at 01:46 PM |
My mounts are fine. I just get a funny diff whine harmonic in the 90-110kph range using light throttle openings. Unfortunately that corresponds
directly with cruising on the highway. Using more throttle / going faster makes it go away.
pete wood
| posted on March 11th, 2009 at 01:14 PM |
I often hear whining in the inside of the car too...and my gearbox does it also
but yes, I know what you mean. I thought it was the albins 4th, but my stock 002 box did it too.
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on March 11th, 2009 at 04:45 PM |
I thought it was my albins 4th too, but I get it in 3rd at the same speeds (although a little more difficult to hear with the higher engine rpm)
20bkombi
Threads: 26
| posted on March 16th, 2009 at 06:29 PM |
Hi wes, is the gear box solid mounted? mine is, and it growles in 5th, 6th because of where the mount is located on the intermediate housing.
Maybe, its the r&pinion
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on March 17th, 2009 at 01:05 PM |
No, not solid mounted. It's vibration free. Yeah, probably the R&P getting old and cranky
beetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
Mood: Drive bugs hard
| posted on March 17th, 2009 at 04:43 PM |
I used to get terrible whining in my L bug, then my wife got her own car.
From your ole' mate Jeff
bajachris88
A.k.a.: Chris Leete
Threads: 534
| posted on March 17th, 2009 at 05:53 PM |
(ô_!_/ô) (ô_!_/ô)
colonel mustard
Threads: 51
| posted on April 9th, 2009 at 10:18 PM |
posted by Baja Wes
At one stage I owned an L bug with a very mild 1776 with twin kadrons.
sorry to resurect a thread... but how did you like that combo sir?
