[ Total Views: 1657 | Total Replies: 22 | Thread Id: 75355 ] |
alien8
Threads: 84
Theme: UltimaBB Powder
posted on March 15th, 2009 at 04:49 PM |
I am completely gutted!
Yesterday I started to colour sand and polish my new paint job. It came out beautiful, so happy. Today I went to do some more work to the car and I
noticed thousands of pimples coming up in the paint under the clear coat. It looks completely f%#$ed, so angry! I had the deck lid finished a few days
ago and wrapped it in a blanket and stored it away. I had a look at the lid and its worse than the body I did yesterday.
I think its the rust converter primer I used. When I was shopping for products to use I was going to get the straight rust converter but I saw a rust
converter primer from the same company. It's the kind that turns black when it dries. The two panels that I didn't use the converter primer on
haven't pimpled at all. Its the only difference between them and the rest of the car. All the etch, primers ,colour and clear coat were the same
through the whole job.
Well anyway, what a complete waste of time and money $600 worth
of paint down the drain.
I am going to give tec. support of the company tomorrow and see what comes of it but I don't think it matters much now. So angry!
Error |
matt
A.k.a.: Choco
Threads: 85
posted on March 15th, 2009 at 04:54 PM |
that sucks!!! all that effort.
i feel for you mate
matt
Camo
A.k.a.: Kev
Threads: 209
posted on March 15th, 2009 at 05:38 PM |
I don't think words could really express how you must be feeling, as I know how I feel when small things go wrong. Make sure you don't have a gun
in your hand when you go see the tech support person, because at this very moment I bet you feel like using one.
Hope it all works out ok and they can help.
Kevin
matberry
posted on March 15th, 2009 at 05:59 PM |
You poor bugger.
Your explanation sounds possible, certainly doesn't make it any easier.
Our shop used to use Wurth brand of this stuff, ok for panel prep, and the Septone I recently bought says not, both do similar job.
Good luck with whatever you decide to do with it.
VWFREAK
A.k.a.: Peter / Bones
VWFREAK
Threads: 264
Mood: FREAKY
posted on March 15th, 2009 at 06:00 PM |
Damm
cnfabo
Threads: 140
posted on March 15th, 2009 at 06:34 PM |
NOOOOOOOOOOOooooooo, ..
thats is i realy nice colour dude. give those tech staff a mouth full and get your cash back.
alien8
Threads: 84
posted on March 15th, 2009 at 06:45 PM |
Yep, a $14 bottle of liquid hell cost me most of my sanity today.
The colour is a VW colour diamond blue. Its a classy colour hey?
After a bit of thought I can either spray it again,nooooooooooooo or just let the paint go septic and dig on the rat look and spray it again in 12
months. By the rate of bubbling maybe it will strip itself in a couple of months.
I keep looking at it and shaking my head.
Thanks for the sympathy peeps, in a way it helps to get over it.
I'll let you know what the tech. guy said.
trickysimon
A.k.a.: Simon Azzopardi
Threads: 43
posted on March 15th, 2009 at 07:07 PM |
Damn! It looks like you did a great job too!
pat Malone
1st Warning
Threads: 0
posted on March 15th, 2009 at 07:13 PM |
I've been told that all rust converters are not to be used !
it just turns the rust Black and not much else.
the only way is to remove all rust before painting.
alien8
Threads: 84
posted on March 15th, 2009 at 07:22 PM |
Looks good from 10' away.
Error |
Joel
posted on March 15th, 2009 at 08:16 PM |
Brad that really sucks, i feel for you mate,
was it your first paint job? like simon said you got a really nice finish on it
eraser
Threads: 128
Theme: UltimaBB Pro Powder
posted on March 15th, 2009 at 08:22 PM |
Damn i know this doesn't help you but it made me realise that this type of thing can and does happen. I will be watching out for this when i get
round to my beetle.
My condolences.
alien8
Threads: 84
posted on March 15th, 2009 at 09:35 PM |
Quote: | Originally
posted by Joel
Yeah it was my first job on a car using auto primers and that sort of stuff but I used to do a lot of airbrushing and polishing on surfboards using
acrylics. I was in the surfboard game for 15 years.
I used 10 coats of clear over 5 coats of colour then wet rubbed 800, 1200, 2000 grit then cut and polished. It came out really good until this problem
with the converter primer. I should of just stuck to rust disolver then a wash down then a straight etch high build primer. I know for next time.
I just found out that the converter primer is latex based.huh!
bajachris88
A.k.a.: Chris Leete
Threads: 534
posted on March 16th, 2009 at 01:20 AM |
Is the pimples in just the clear coat? or the colour coat too?
(ô_!_/ô) (ô_!_/ô)
vw54
posted on March 16th, 2009 at 05:47 AM |
looks like humidity blisters
was the surface moist before you applied the colour ???
kombivw
A.k.a.: David
posted on March 16th, 2009 at 07:04 AM |
Do feel sorry for you. i made a similar mistake but as I was just touching up a fairly ordinary paint job, so was no biggie. I applied a two pac oven
bake paint with a hairdryer over some work I had done in various areas. Blistered bad and took an age to dry. I dont know the rust stuff you used but
was there any warnings? it may be worth actually writing to company and also seeing whether the fault is yours or there's?
vwsteve
A.k.a.: steve
karmann crazy
Threads: 200
Mood: Busy!
posted on March 16th, 2009 at 08:23 AM |
yes you may want to find out if its humidity blisters(water in air line )or solvent boil
1 1963 356b porsche coupe
2 1960 karmann ghia cab
1 1965 karmann ghia cab
1 1966 karmann cab
1 1961 split ute
1 1967 split p/van
1 1952 standard bug
1 1963 ragtop
1 1960 ragtop
2 1954 ovals
1 1956 oval baja project
1 1957 oval flying flea
alien8
Threads: 84
posted on March 16th, 2009 at 10:22 AM |
The pimples are under the colour. I can wet rub them out with 2000 grit but within 8 hours they start coming back. They are only on the panels that
were coated in this converter primer. The body was sprayed on a dry sunny day and no water was in contact with the metal for over a week.
I use two water traps on my lines, one at the compressor and one 8' before the gun. The pimples look like if you got a heat gun and blistered the
surface lightly. Weird thing is that they wet rub totally flat and 8 hours after polishing their back. I use very light pressure when I polish and
don't let the panel heat at all.
Hope someone can tell me what going on. I appreciate all the feedback.
vw54
posted on March 16th, 2009 at 10:38 AM |
humidity the body work has to be kept dry when primer has been applied
alien8
Threads: 84
posted on March 16th, 2009 at 11:01 AM |
I just talked to the company rep and they know about the problems with the product. I am not the first to have this problem with the converter primer.
If the surface is not heavily rusted the product will have problems. The acid keeps reacting with the bare metal unless it has a heavy rust coat. It
should be only used as a temporary coating for heavily rusted repair sections. Damn, I wish the bottle said that.
The best course of action is to strip it back and paint it again. Least I know now that its not an isolated case. I feel less stupid.
guru
A.k.a.: Mr. Meaner
Mood: ...Jolly calm at the moment, but that could change in half a millisecond
posted on March 16th, 2009 at 12:00 PM |
Has the rep offered some products to ease the pain? Nothing on the bottle and all.....
alien8
Threads: 84
posted on March 16th, 2009 at 01:52 PM |
Quote: | Originally
posted by guru
Nope, the rep suggested I take it up with the retailer and I will mention something if I go get more supplies for a respray.
There's nothing on the bottle that suggests intended use. It does say to apply to rusted surface. I let the body develop a surface rust but not a
heavy rust like the rep suggested. Nothing on the bottle about repair use only.
In the end its my fault, I used the product after all .I am just deciding weather to respray or just leave it as is now.
rob53
Threads: 62
posted on March 19th, 2009 at 09:20 AM |
That is really unfortunate, it looked like a real nice paint job. But atleast this time when you strip it back, it should be a lot easier since the
paint is still fresh.
Thats not rust, it's ah ... orange primer ... yep that's what it is ...
