| [ Total Views: 1376 | Total Replies: 8 | Thread Id: 76293 ] |
V-Dubber
Threads: 14
Mood: Excited
| posted on May 2nd, 2009 at 11:23 AM |
Rims for the 4 stud type 3
Hi again all, just a question pertaining to the hub axle of the type 3's, mine has a 4 stud pattern which I am sure most if not all have. I was
wondering what is the largest rim I can put on and can other car manufacturers rims fit??..... Failing all of this does anyone know were I can get 5
stud pattern hub axles to go all round on the car fronts and backs ?
Thank you for any information and " keep on dubbin' "
Even the Alphabet loves it!
abcdefghijklmnopqrstu VWxyz
68AutoBug
| posted on May 2nd, 2009 at 11:42 AM |
the four stud pattern on Late type 3s is the same as beetles from 1968 on...
the type 3 rims were 1/2 inch wider than beetle rims...
6 inch is usually the maximum... IMHO...?
Joel
| posted on May 2nd, 2009 at 08:39 PM |
17x7 is a squeeze under type3s but can be done
but re; the stud pattern 4x130 was common only to vw bug, type3 and karmann ghia and only late model at that
theres the odd model of skoda that had it and porsche 914 but nothing else which can make rim hunting painfull
Aside from that best option if you dont want ugly 70s wheels like hotwires, jelly beans or 8 spokers is to get some restudded brakes in what ever
pattern you like then the options are endless
V-Dubber
Threads: 14
Mood: Excited
| posted on May 2nd, 2009 at 11:13 PM |
Cheers for the information guys, has put me on the right path, I will probably try and find some 5 stud hub axles to suit so I can increase my tyre
size and change from drums to cross drilled vented discs
notch-72
| posted on May 26th, 2009 at 09:45 PM |
Hey V-Dubber ,Did you find a 5 stud hub axle yet, im in the same boat want to change to 5 stub for more wheel choice, Has anyone else done this yet ..
V-Dubber
Threads: 14
Mood: Excited
| posted on May 27th, 2009 at 08:40 AM |
I haven't found 5 stud conversions, but I did find a 4 stud disc brake conversion at around $500 on ebay
heres the link,
Ebay Brake Disc
Conversion, 4 stud
I aint got the $500 yet but they have a few so I might get lucky
Am still searching for the 4-5 stud conv. though will keep all interested parties up to date on when and where
RATAFIED
Threads: 50
Theme: UltimaBB Psyche Green
Mood: LOL
| posted on May 27th, 2009 at 04:27 PM |
i found a add in the vw mag which has wheel adaptors for 4 too wide 5 stud pattern disc brake conversoins
but i couldnt find them on there site
http://volksconversions.com.au/Brakes.html
[size=6]RUST IN PEACE[/size]
Klaus
Threads: 100
Mood: Heavily modified
| posted on June 5th, 2009 at 04:49 PM |
not that hard you can buy blank discs front and rear and get drilled in any pattern , john sherman from volksconversions also check the empi online
catalogue, , latest rage , buy the us vw mag "hot vw" and see what they have .
newghia
A.k.a.: Noddy
Threads: 30
Theme: UltimaBB Pro Charcoal
Mood: nood !
| posted on June 6th, 2009 at 07:29 AM |
Hi Guys, try Volks Conversions in Qld (john Sherman) for stud patten changes,
or http://www.vforce.com.au for a 4 stud wheel , Its only 15 x 6 though. $188 each (
6.5 kgs )
same ones on the red razor at the Nats.
Or AIRKEWLD in the states, disc brakes any patten & billets to fit.
Noddy.
Step up to get out !!!
