[ Total Views: 826 | Total Replies: 11 | Thread Id: 76925 ]
Author: Subject:  replacement indicator arm for early type 3 ideas?
Membertype3lover
A.k.a.: The Smashed Repairer
in the garage...
Threads: 90
Mood: stoked
posted on June 1st, 2009 at 07:06 PM
Greetings!
My indicators won't cancel and the assembly is shagged.
I need to find a replacement whether vw or something from another car. Mine is the early type steering column.
What are people using?
Cheers, T :tu:
Member1500S
Threads: 73
posted on June 1st, 2009 at 08:18 PM
But which "early" type. The one with the steering lock/ignition switch across the top of the column or the simple one with ignition switch dangling below column ? The top ones are as rare as rocking horse .. well you know .... but the lower one can be addapted from a similar model Bug. You will have to fiddle a bit to put the headlight dipper switch into the arm.
DH
Membertype3lover
in the garage...
Threads: 90
Mood: stoked
posted on June 1st, 2009 at 08:37 PM
Thanks Dallas
Mine is the same ignition switch as the lower pic.
Can the beetle arms you mention be purchased new still and are they any good?
I have the dipper switch integral to the stalk. How much "fiddling" are we talking about?
Member1500S
Threads: 73
posted on June 1st, 2009 at 08:40 PM
Have my phone number in PM. Give me a call in 10 minutes.
DH
Membergrumble
Mood: happy all the time
posted on June 1st, 2009 at 09:06 PM
Weren't these similar to the ghia?
Membertype3lover
in the garage...
Threads: 90
Mood: stoked
posted on June 1st, 2009 at 09:19 PM
Thanks D great chatting with you!
Hey Grumble I have no idea...maybe someone else knows?
Still looking...
Member1500S
Threads: 73
posted on June 1st, 2009 at 09:20 PM
A Bug assembly will be ok but he may have to put up with an ivory one. Can't remember if Bugs had the black things..... toooooo long ago! Only a coat of paint though.
DH
MemberKlaus
Threads: 100
Mood: Heavily modified
posted on June 2nd, 2009 at 10:23 AM
converted mine to dipper switch think it was only drilling and tapping a very small hole for switch to pivot on .
Membertype3lover
in the garage...
Threads: 90
Mood: stoked
posted on June 2nd, 2009 at 05:27 PM
Thanks Klaus that's pretty much what 1500S mentioned to me as well.
I have been told that mine is most likely serviceable so I'm going to have a go at it...starting with disassembly and a good clean!
Still, I do like the idea of a non VW one say like a BMW or similar (german if possible!)
Spent hours at the wreckers and couldn't find anything suitable.
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on June 2nd, 2009 at 06:01 PM
not cheap, but have recently seen new ones (yes type 3 with dipper) going into a hot rod.........will find out where they came from.
Membertype3lover
in the garage...
Threads: 90
Mood: stoked
posted on June 2nd, 2009 at 06:32 PM
Thanks Daimo!
Interesting choice...was it a VW hot rod? :smilegrin:
If you do happen to find out that'd be cool.
U have a PM too
Cheers! T :tu:
MemberREDKG
posted on June 3rd, 2009 at 05:11 PM
ghia & type 3 are the same. early ghia used the switch to flash the headlights and type 3 used it for hi/lo beam. i used a beetle one , just swapped the switch over. there are repro ones about.
[ Queries: 40 ] [ PHP: 17.9% - SQL: 82.1% ]
