| [ Total Views: 1186 | Total Replies: 12 | Thread Id: 77349 ] |
Peanut_finger
Threads: 6
| posted on June 22nd, 2009 at 11:32 AM |
Bad Understeer
I have a 1972 type 3 fast back and i am havving pretty bad understeer. I havent had a alignment done on the car since i have brought it and i suspect
it has bad "toe out" on the front.
Can anyone advise what the handling on a Type3 is normally like?
squizy
| posted on June 22nd, 2009 at 02:14 PM |
You should find it's pretty neutral, but they will understeer if you push too hard into a corner, with lift off oversteer to help straighten it back
out on hand. What sort of tyres are you running? Are they standard width and in good condition? What about shocks and ride height? There are many
variables in handling setup. My 1970 Notchback handled great.
shaihulud
Threads: 197
| posted on June 25th, 2009 at 08:54 AM |
Something to consider is how old the tyres are.
I recently bought a 1970 Beetle with very old tyres with good treads but very hard rubber. They transmit every bump on the road.
In the wet there is very little traction and the understeer is a bit scary.
I'll get new tyres soon enough, but in the meantime I drive it very carefully.
Could that be part of your problem?
typethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
| posted on July 2nd, 2009 at 06:35 PM |
i have a 71 fastback and with plenty f power on board you can get heaps of understeer, but when i had a stock 1600 in the car and it was really low
ididnt get under or oversteer. Type 3 are alittle know to get understeer with standard ride height but with some suspension changes you can get it
sorted..
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on July 2nd, 2009 at 09:11 PM |
Toe out will help the car turn, not understeer.
BRUTUS
A.k.a.: et tu, Brute
Threads: 17
Mood: ACE 30 FOR SALE!
| posted on July 5th, 2009 at 06:22 PM |
Type 3's can give either slight understeer or oversteer, and should be one of the best handling cars on the road! We need more info. on the
car...
Set up properly (tyres; alignment etc.) they should be fairly neutral (as Squizy said), and you should also be able to change from slight understeer
to some oversteer just by changing the F:R tyre pressures!
ACE 30 & 40 oils: specifically engineered for your Air Cooled VW
delivered (free del.) throughout Yarra Valley / Ranges, & Gippsland areas. Also ACE 20, 50 & 90.
FOR SALE: ACE 30, 40 etc. Oil formulations & Trade-names.
Peanut_finger
Threads: 6
| posted on August 27th, 2009 at 11:13 AM |
THe car had a wheel alignment, so much better now.
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on August 27th, 2009 at 12:31 PM |
posted by Craig Torrens
I use 2mm toe-out on my black-ish '59 Beetle to PROMOTE under-steer!
Doctor
Threads: 15
| posted on August 27th, 2009 at 02:49 PM |
posted by HappyDaze
Thats something my father would do, he prefers to drive a car with understeer, i hate it, but each to their own!
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on August 27th, 2009 at 03:54 PM |
posted by Doctor
posted by HappyDaze
Sounds like us old blokes know what we're doing eh?
trickysimon
A.k.a.: Simon Azzopardi
Threads: 43
| posted on August 27th, 2009 at 07:26 PM |
Give me snap oversteer before understeer anyday
Doctor
Threads: 15
| posted on August 27th, 2009 at 10:10 PM |
posted by HappyDaze
posted by Doctor
posted by HappyDaze
Thats one way to look at it, as in my sig, Oversteer scares the passengers, Understeer scares the driver...
Id rather have oversteer, something thats relatively contrallable, but understeer is something i cant stand, small amounts are ok, but mass understeer
would have me spending coin on a suspension revamp!
Different Generations do things differently!
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on August 28th, 2009 at 07:34 AM |
There is no need for anybody to be scared - it all should be fun! I am talking about Beetles, so at some point oversteer wil need to be addressed.
Having raced - and still racing - Beetles for 50 years, I've had heaps of oversteer (and understeer) to deal with. I have found that my personal
preference is for initial understeer, then CONTROLLED oversteer, using the right foot - it's a lot of fun, believe me, if you don't already know!
Cheers, Greg
