| [ Total Views: 1213 | Total Replies: 10 | Thread Id: 77816 ] |
pod
A.k.a.: paul mrvw061
Mood: could be better
posted on July 14th, 2009 at 06:21 PM |
genny to alternator question
i`m putting an alternator on my semi auto,can you use the original fan backing plate part off the 12v genny or do i have to use the cheap tinny
looking thing that came with it???
grumble
Mood: happy all the time
| posted on July 14th, 2009 at 08:51 PM |
I would use the original plate
pod
| posted on July 14th, 2009 at 08:56 PM |
Thanks Les,i will use all the og parts
Joel
| posted on July 15th, 2009 at 03:53 PM |
i'd advise it too, those aftermarket ones are cut from al foil by blind taiwanese children with scisssors
vw54
| posted on July 15th, 2009 at 04:49 PM |
use the origional
but make sure you fit it in the correct position so the cooling vent works for the bearings
1303Steve
| posted on July 15th, 2009 at 06:40 PM |
Your 12 volt generator stuff should work, some Kombi generators had different tin. Do a check when its together for belt alignment.
pod
| posted on July 15th, 2009 at 09:18 PM |
Dave ,have put it on the way it came off genny,and Steve will do once back together ,don't want to wear belts prematurely or have them throw off
ctefeh
Threads: 30
Mood: grimly determined
| posted on July 16th, 2009 at 04:34 PM |
Paul,
Absolutely re-use the gennie twinware & hardware (fan hub, woodruff keys, spacers etc). It is far better quality. The slot faces down, just
in case you need to re-orient it. A few things to watch?
Make sure the Alt doesn't hang up on the alt stand. It is the alt lower two ribs that may do it. Judicious angle grind fix.
Running an alt fuel pump? Make sure your pump rod is 100mm. I got supplied a 108mm (Gennie) pump rod with my alt pump.
Carb accelerator pump linkage may interfere. Definitely will on a 1600DP with a Gennie 34 Pict 3. Brutalise/bend or Grind the alt body.
Here's a cheap read :
Regards
Sean
ctefeh
Threads: 30
| posted on July 16th, 2009 at 04:37 PM |
Paul,
Carb accelerator pump linkage may interfere. Definitely will on a 1600DP with a Gennie 34 Pict 3. Brutalise/bend or Grind the alt body or buy a spacer
to raise the carb.
Here's a cheap read : http://forums.aussieveedubbers.com/viewtopic.php?tid=50478
Regards
Sean
pod
| posted on July 19th, 2009 at 09:59 PM |
well its all in and working with no dramas of grinding etc.Petrol pump to alt clearance of about 1 - 2mm ,carby had no probs plenty of room (maybe
cause its a single port ?????) ..And the belt alignment was perfect ,so one happy chappy next to do the same with my 1600tp out of my baja as part of doing a ring change and stud replacement
Joel
| posted on July 19th, 2009 at 10:16 PM |
its only the early pict-3 carbs with the adjustble pump stroke towards the back of the car that have clearance issues
but that is easily gotten around
