| [ Total Views: 5462 | Total Replies: 7 | Thread Id: 78503 ] |
kg1962
| posted on August 19th, 2009 at 07:25 PM |
T34 ghia LHD to RHD conversion
Just wondering if anyone knows how hard and costly it is to convert a T34 Karmann Ghia from LHD to RHD.
vwsteve
A.k.a.: steve
karmann crazy
Threads: 200
Mood: Busy!
| posted on August 20th, 2009 at 06:23 AM |
it would be easy if you buy mine for $3500 and use the parts(complete car)
1 1963 356b porsche coupe
2 1960 karmann ghia cab
1 1965 karmann ghia cab
1 1966 karmann cab
1 1961 split ute
1 1967 split p/van
1 1952 standard bug
1 1963 ragtop
1 1960 ragtop
2 1954 ovals
1 1956 oval baja project
1 1957 oval flying flea
kg1962
| posted on August 20th, 2009 at 07:26 PM |
I am actually looking to buy a t34, and was wondering if I should import a LHD and convert it, since there aren't that many around. I would prefer
one that doesn't need too much work but send me pics and details of yours and I'll consider buying it.
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
| posted on August 20th, 2009 at 08:49 PM |
You don't need to convert it to rhd ,to get it rego , better to leave it in original condition .
kg1962
| posted on August 20th, 2009 at 09:36 PM |
posted by Dak-A-Tak
Is that also true in NSW?
lardo
Theme: UltimaBB Vintage
Mood: just short of teriffic.
| posted on August 21st, 2009 at 06:44 AM |
Over 30 years, yes.
T-34
A.k.a.: Mick
Threads: 35
| posted on August 25th, 2009 at 10:57 PM |
posted by rexy
Would prob cost about this much!
Hardest part would be finding the parts - RHD dash pads are like hens teeth - in fact finding ANY dash pads is a nightmare. Basically all Type 34
specific parts are not easy to come by, especially stuff like the steelwork for the dashboard. The only way you might be able to do it is either wait
a long long time to collect all of the parts (it would take years) - or simply pay premium prices for them (or buy rexy's of course)
Off top of my head...
Beam is stock type 3
Same as pedal assembly
Can reuse the steering column
Vent wing frame is threaded for mirror - and you only get one mirror so you need a RHD Drivers vent frame - or just use a non standard mirror.
Mirrors are also Type 34 specific as thread is very short (even convertible bug ones don't fit)
Got a feeling the fuel tank is different for RHD / LHD as it is clearanced for steering column.
Glovebox liners are hard to find (I have a repro one I will sell you, but the fit is shite - lol)
Wiring loom is different (wires will not reach gauges) so you will need a RHD front loom.
You may also need to relocate fuse box - depending on how much of dash you cut out and swap.
Front carpets are different - for pedals and steering column
Front pedal / foot plates are Type 34 specific (I think)
If you are taking all of the dash out you might as well overhaul the fresh air vents and windscreen wiper motor / mechanism so allow $$ for this
You will probably need to remove front screen for welding etc so factor in a front screen seal
You will also need to paint the dash and probably repaint the front vent panel.
Then you either need to pay someone to do the work - or do it yourself
(did you think I was kidding when I said $3500)
Just not really worth it in my opinion unless you can get a doner car for nothing, or you just want to do a hack job / custom job. But remembering
that even basket case Type 34's seem to be pulling cash these days you would have to be pretty lucky.
Mick.
vw54
| posted on August 26th, 2009 at 07:30 AM |
yep leave it LHD much cheaper and you can register in NSW no problems
