[ Total Views: 1122 | Total Replies: 9 | Thread Id: 78630 ]
Author: Subject:  Headlights...
MemberDoctor
Threads: 15
posted on August 25th, 2009 at 03:36 PM
Headlights...
So as a few people know, i recently purchased a type 3 square of another forum member, im currently in the process of piecing it back together and getting it back to a roadworthy state.
I have run into a problem though with the headlights, given that i didnt remove them i have no clue what wires go where...
here are some pics of what im facing...
http://drmphotography.net/wp-content/gallery/the-docs-ride/img_8488.jpg
http://drmphotography.net/wp-content/gallery/the-docs-ride/img_8489.jpg
http://drmphotography.net/wp-content/gallery/the-docs-ride/img_8492.jpg
http://drmphotography.net/wp-content/gallery/the-docs-ride/img_8491.jpg
http://drmphotography.net/wp-content/gallery/the-docs-ride/img_8490.jpg
Any help would be greatly appreciated!
http://www.brassmunkymedia.com.au
Any car so nice you can't drive it in the rain.. is too damn nice to enjoy
http://www.brassmunkymedia.com.au/wp-content/gallery/the-docs-ride/olliewilliams1copy-dub.jpg
Memberelectricmonk
A.k.a.: Jason
Threads: 56
Mood: Indego
posted on August 25th, 2009 at 03:52 PM
There are wiring diagrams over at http://www.thesamba.com/vw/archives/info/wiringt3.php
These may be of help. If you need it I can take a look at mine tonight and take a picture. The cars stripped for a rebuild but I should be able to find something that will help
And they shall beat their swords into plowshares, for if you hit a man with a ploughshare, he'll know he's been hit
MemberDoctor
Threads: 15
posted on August 25th, 2009 at 04:32 PM
Cheers, any help will be handy, i would love to be driving this by the weekend for a photo shoot im doing!
posted on August 26th, 2009 at 07:24 AM
The white wire is hi beam
the yellow wire is low beam
the grey wire is parker
the brown wire is earth
the black n green is blinker
the brown goes to the headlight globe next to the white n yellow and then to the parker and finally onto the blinker junction
Memberelectricmonk
A.k.a.: Jason
Threads: 56
Mood: Indego
posted on August 26th, 2009 at 08:00 PM
vw54 has already answered, Mine are all disconnected as I am in the middle of rust repairs, but a quick mock up agreed with the above post.
MemberDoctor
Threads: 15
posted on August 27th, 2009 at 02:47 PM
Thanks for your help guys, me and a mate are tackling the problem at the moment. We have headlights, we are unsure if we have indicators at this stage, have to check the globes, but we have come accross another problem.... High Beam... Is the high beam in this car turned on using the indicator stalk, is it push forward or pull backward? Pulling backward does nothing when the lights are on or off, we get no change at all... in My last type 3, i had to pull the indicator stalk back fairly firmly to get it to click and turn high beam on, was this different on earlier models?
posted on August 27th, 2009 at 03:15 PM
Is a headlamp dip switch on the floor???
some VW models [not usually in Australia]
had the dip switch located right at the end of the blinker lever.
Member1500S
Threads: 73
posted on August 27th, 2009 at 03:52 PM
Hi Lee. A few Type 3 Notches (maybe Squares as well) had the dimmer switch on the firewall. I only ever saw about two of these OZ built ones from the 1964 model. Maybe VW OZ weren't given enough of the indicator dimmer switches when they started production here!
All other Type 3s had the dimmer on the end of the indicator arm. First off the small button up to around 1968 and then the whole arm moved for the dimmer. Early imported ones had the headlight flasher incorporated in the relay as did the 1500S and the early imported Fastback which used the same steering column.
Just some more useless information for someone to read!!:lol:
DH
MemberDoctor
Threads: 15
posted on August 27th, 2009 at 03:53 PM
Nope, no switch on the floor, although it did cross my mind...
MemberDoctor
Threads: 15
posted on August 27th, 2009 at 03:54 PM
DH
Thanks, i have seen the indicator stalks with switches/buttons in the end, but mine doesnt seem to be one, its a 1970 if that helps anyone... So far we have Headlights/parkers working, but no indicators, so just trying to find out if its a blown globe at the moment, im currently meant to be looking for a screw driver to remove the lens, but im posting here instead!
[ Queries: 40 ] [ PHP: 17.4% - SQL: 82.6% ]
