| [ Total Views: 944 | Total Replies: 7 | Thread Id: 78840 ] |
chev10
Threads: 3
posted on September 2nd, 2009 at 09:38 PM |
What year is it
Hi,
I have just purchaced an early Bug to fix up and give to my daughter. I would like to know the actual year the car was manufactured. previous owner
said 62 or 63 !!. The vin# is 195026567. There is no Australian compliance plate. Well not that I can find anyway. Did find some rust!
I'm sure someone here can help.
Thanks.
I've got a 73 bay that I will hopefully get a start on once I finish this bug, Owned a splitty when I first got my licence. many many years ago
cost me $800.00 Wish I still had that now.$$$$
1303Steve
| posted on September 3rd, 2009 at 03:30 AM |
Thats an Australia only chassis number from 1965.
vw54
| posted on September 3rd, 2009 at 06:58 AM |
yep 1965 model or at least the chassis is
chev10
Threads: 3
| posted on September 3rd, 2009 at 10:06 AM |
Hi,
Thanks for that. Does that explain why there is no Aussie comliance plate on the bug.
I'm sure the body is original to this chassis, but is there a way of confirming this ? ie changes to body or fittings etc.
John.
68AutoBug
| posted on September 3rd, 2009 at 11:37 AM |
posted by chev10
Hi,
John.
Hi John
there should be a plate under the bonnet..
behind the spare wheel...
they didn't use compliance plates back then...
the chassis and engine number were checked.... and still are..
chev10
Threads: 3
| posted on September 3rd, 2009 at 12:04 PM |
Thanks Lee,
I have looked every where, that was the first place I looked. I hope this wont be a problem when I go to get it registered.
I'm also replacing the old engine (stuffed) with a 1600 twin port. do you think this will be an issue ? I know I have to clearance the bell housing
to suit the flywheel.
Thanks,
John.
1303Steve
| posted on September 4th, 2009 at 11:02 PM |
Depending on the people who register the car, you should have front disk brakes if your fitting a motor that size.
You need to fill in your location on your profile so that advice can be offered suitable to where you live.
chev10
Threads: 3
| posted on September 5th, 2009 at 04:13 PM |
Hi Steve,
Thanks for the reply.
Actually didn't think about that (disc brakes)! Yeah I think if my little girl is going to drive it, then it "must" be a safe as I can make it.
Would adapting disk brakes be a straight forward change out set up , or is it more involved ?
Any advise on how to and what to do etc would be greatly appreciated.
John.
