[ Total Views: 1219 | Total Replies: 8 | Thread Id: 80145 ]
Author: Subject:  maybe its all in your head(s)
Memberrocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on November 7th, 2009 at 04:51 PM
EJ22
[img]http://i5.photobucket.com/albums/y172/rocknrob/ports002.jpg[/img]
[img]http://i5.photobucket.com/albums/y172/rocknrob/ports007.jpg[/img]
EJ20T
[img]http://i5.photobucket.com/albums/y172/rocknrob/ports004.jpg[/img]
[img]http://i5.photobucket.com/albums/y172/rocknrob/ports006.jpg[/img]
exhaust port similar story...about 35mm versus around 40mm...heheh couldn't be bothered lying in the dirt to take a pic...anyway pics say it all:yes:
Memberseagull
Threads: 752
posted on November 8th, 2009 at 01:38 AM
keep it clean man & were is the steel cap boots ?
also what motor did you end up picking up & what was the turbo ?
Memberrocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on November 8th, 2009 at 04:41 PM
Hi Neil..got a 98 forester gt obviously boost friendly but only comes with a tiny TF035...my TD04 will be going on to start with. One neat thing that came with it is this alloy header tank...much better than the plastic falcon one i'm using:tu:
[img]http://i5.photobucket.com/albums/y172/rocknrob/ports.jpg[/img]
Memberseagull
Threads: 752
posted on November 9th, 2009 at 12:38 AM
The TF035 is a wast of time and more suited to one of the air cooled guys so move it on. In a heavy bus the TD04 is better suited , or go for a VF34 for a blast as you have yellow 440 cc injectors you on a winner. Yep those tanks are the best you can get
MemberElusiveStranger
Threads: 30
posted on November 24th, 2009 at 10:39 AM
Can I semi hijack on here please? Ta ;)
Anyone know if EJ20 Nat Asp and EJ20 Turbo exhaust ports are the same?
I'm wondering if I can fit a aftermarket Turbo header onto my Nat Asp EJ20.
Memberrocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on November 24th, 2009 at 11:54 AM
I would say yes:yes: I just swapped over my homemade headers from the EJ22 to the EJ20T the inlet manifolds are a different story tho
Threads: 30
posted on November 24th, 2009 at 07:52 PM
Thanks Rob, nice to have it confirmed
Memberseagull
Threads: 752
posted on November 24th, 2009 at 10:52 PM
If your ej20 n/a motor is a quad cam. Your block will be a closed deck case c/w oil squirters like the early wrx turbo motors of that year. Its a good case with very poor pistons & rods , however swap them out and fit turbo heads , rods & pistions and you have a very good motor
Threads: 30
posted on November 25th, 2009 at 01:49 AM
Thanks Seagull but mine's a SOHC
[ Queries: 40 ] [ PHP: 13.3% - SQL: 86.7% ]
